Rev limits at 4k
Old 10-18-2023, 07:45 PM
Johnny_sgh's Avatar
Default Rev limits at 4k
I have just recently bought a 1990 accord as daily but for some reason it’s can’t go past 4k. It’s sluggish to get up to speed and just slow. It has a check engine light but I am still figuring out how to ready obd 1. Anyone know what’s going on?
I have the f22a1 the sohc no vtec
Old 10-18-2023, 08:52 PM
nicolaselias's Avatar
Default Re: Rev limits at 4k
Whatever is causing the CEL is what has you in limp mode and wont let you rev.
You should use the paperclip OBD1 reader method and see what if any code you get
Old 10-19-2023, 02:19 PM
Micro1989lxi's Avatar
If Nicolas's suggestion does not work, the timing off (belt slipped a tooth) 2nd thought would be low compression, if the head gasket failed between 2 cylinders.
Old 10-19-2023, 04:14 PM
Johnny_sgh's Avatar
I tried the paper clip method but couldn’t get the lights to flash. If I clear the codes by disconnecting the battery the car gets out of limp mode the light shortly returns after a couple hours
Nharv
01-13-2019 05:42 AM
Aisha
11-13-2017 08:15 PM
dracer_accord
10-13-2016 10:56 PM
honduhxD
04-25-2006 06:06 PM
purpl7duece
08-25-2002 11:32 PM
Quick Reply: Rev limits at 4k
