Problems with overheating
Old Nov 14, 2013 | 12:52 AM
hondalove90's Avatar
Default Problems with overheating
I just bought my car and on the way home the temp gauge went all the way up and when I lifted the hood I saw coolant spewing from the back what does this mean?
Old Nov 14, 2013 | 05:07 PM
holmesnmanny's Avatar
Default Re: Problems with overheating
It means you have a leak. Could be a number of things. But normally it's a coolant hose busted. If it really went to the top of red then there could be head gasket damage. First thing to do is do a compression test to see if the head gasket is good. If that checks out ok, then you need to find and fix the underlying problem. It's best to actually tell people exactly what kind of car you're talking about.
Old Nov 18, 2013 | 01:21 PM
Oh sorry yeah I have a 96 accord ex 5spd I think it's spitting out coolant from the throttle body could it be a valve?
Old Nov 18, 2013 | 02:09 PM
foxyride22's Avatar
where exactly is your leak coming from? there might be a possibility of a faulty water pump and if thats it then boy oh boy thats gunna be a fun fix.
Old Nov 19, 2013 | 04:00 PM
darkfox1009's Avatar
The back near the firewall? If that's the case, it might be on your intake plenum. I know it sounds weird but here is a diagram. This happens sometimes when the system is under pressure, and it pops off. Or it may have a crack in it. Mor einfo would be much appreciated BTW this was a pain in the butt to get to, so GL!
kykev79
Jun 24, 2017 04:00 AM
single_slam
Feb 3, 2014 01:22 PM
bandit080000
Honda Civic (2001 - 2005)
Jul 1, 2010 11:09 AM
A-dub5513
May 18, 2009 04:08 AM
jdmsohc2nr
Dec 6, 2007 06:04 PM
