Problem with dash lights.
Old Jul 14, 2006 | 06:41 AM
IsweatHONDA's Avatar
Default dash lights acting wierd
my dash lights are acting wierd......the left and right light up but the middle doesnt........on my speedometer 80-140mph and the gas gauge has no lights.......is it just a bulb or 2? anyone have a DIY
Modified by IsweatHONDA at 11:06 AM 7/14/2006
Modified by IsweatHONDA at 11:18 AM 7/14/2006
Old Jul 14, 2006 | 10:19 AM
Accord2k-Hybrid's Avatar
Default Re: not happy (IsweatHONDA)
My wife's friend had a problem with her dash lights for a year and ask me to look at it, so I drove it one night and smacked the **** out of the dash window thing and the lights fixed. If that dosn't work, check wires/voltages/fuses, etc.
Old Jul 14, 2006 | 11:11 AM
02 accord's Avatar
Default Re: dash lights acting wierd (IsweatHONDA)
Do you really need instructions? Pull out the cluster, see which bulb doesn't work (I'll give you a hint: it's the one between the speedo and gas gauge), and replace it.
Old Jul 14, 2006 | 11:35 AM
well lemme just say that i do need instructions, i didnt come outta my mother knowing about cars smartass. by the way, if you dont have any helpful advice then just shut up, i dont need your sarcasm!!
Old Jul 14, 2006 | 02:51 PM
02 accord's Avatar
Default Re: (IsweatHONDA)
I was being serious. Sorry if it didn't seem that way. Your 00 should be the same as my 02, so remove the 2 screws from the trim around the cluster (they're on top), and pull out the trim. Two clips are holding it in on the bottom, which could be a pain in the *** to remove. Remove the four screws holding the cluster in place (2 on top, 2 on bottom). Pull out the cluster, and unplug the wiring. You will have holes in the white cover (back of cluster), and inside those holes you will have black round bulb holders. 1/4 turn to the left, and they come out. The rest should be obvious.
Old Jul 14, 2006 | 03:33 PM
Default Re: (02 accord)
im sorry.....i thought you were making fun of me because i dont know much about these things....i must have taken it the wrong way....im sorry.
thanks for they instructions........i really appreciate it
DanGAvery
Nov 30, 2018 04:35 PM
VTECtravler
13
Oct 4, 2006 07:51 AM
Vtec77
May 27, 2005 07:29 AM
civicflow
Jan 27, 2005 07:06 PM
