please help
Old Mar 13, 2006 | 07:19 PM
elijah's Avatar
Default please help
i have a 95 honda accord coupe. my tranny started leaking fluid the other day, so my mechanical told me it was the front seal in it. never had any issue with the tranny changing gears or nothing. so he changed the seal and since he had it broke down put 2 front axel in it 2. the leaking problem has stop. but now i notice the d4 light on the cluster is blicking all the time, no matter what gear i have it in. and also it seem to come out of first gear kind of quick and when it does the motor gets a very light tone, gets real quiet. but the other gears are not like that, they are fine. this other guy told me he thinks its my accelerator cable, because it has to much slack in it. but i dont have a clue. can someone please help with this
Old Mar 13, 2006 | 08:24 PM
P_Adams's Avatar
Default Re: please help (elijah)
Have him recheck both the trans fluid level (he may have neglected to refill it) and for any wiring connectors he may have disturbed.
On that Transmission you have two shaft speed sensors, two shift control solenoid packs (two solenoids each) and a Vss (Vehicle Speed Sensor). All of which can effect both the Transmission operation and cause the TCM (Transmission Control Module) to set a code and start the D4 lamp blinking. Aggravating, isn't it?
If everything appears to check out, you'll have to retrieve the DTC (Diagnostic Trouble Code); which will help point the way.
P
Old Mar 13, 2006 | 08:34 PM
elijah's Avatar
thanks alot for the help, could u please tell me how would i check the code, i know there is a connector that checks if the service engine light is on. the one under the dash on the driver side
Old Mar 13, 2006 | 09:11 PM
P_Adams's Avatar
I'm trying to dig up the proceedure for you, let me see what I can find.
P
prelewdracer
Aug 14, 2010 06:48 AM
darinkk
Sep 25, 2009 08:16 AM
jdmsteve2004
May 24, 2004 08:29 AM
Nerologic
13
Sep 28, 2003 10:25 PM
