overheating problem
Old Jun 27, 2006 | 05:54 PM
heated honda's Avatar
Default overheating problem
i have been having overheating problem in my 88 accord. i have replaced thermostat, temp fan switch, tested relay switch works fine, put in new radiator, both fans work, no broken fins, replaced water pump, all hoses, the bypass hoses,all new parts. cleaned and inspected the metal pipe that is under the intake manifold, and flushed the engine out with clean water. i have wired the fans to run all the time to keep the engine cool but it still gets really hot on hot days and also gets really hot at freeway speeds, even with the fans running continuously. The next thing i will try is getting a aftermarket high cfm fan to help cool. this cooling problem has already cost me one engine. Any suggestions would be appreciated.
Old Jun 27, 2006 | 06:39 PM
hondadude's Avatar
Default Re: overheating problem (heated honda)
Is the radiator plugged up? A new radiator would cost much less than a new engine
Old Jun 27, 2006 | 10:26 PM
Honda-Master's Avatar
do a leakage test , to make sure you don't have a blown head gasket
Old Jun 28, 2006 | 04:09 AM
H22A 94Inspire's Avatar
I know u said u put in a raditor but if u got it at a junkyard or if its used then check underneath the hose at top they like to crack right there on accords
Old Jun 28, 2006 | 07:21 PM
Default Re: overheating problem (hondadude)
as stated in my description of what i all i replaced all the parts i replaced were all brand new from the parts store.
cgeorge
Aug 3, 2015 08:44 AM
marylou
36
Jul 26, 2010 02:41 PM
jeremyrocksursox
Oct 20, 2009 05:54 AM
AcuraFanatasism
Sep 20, 2009 02:55 PM
fe519
Jul 27, 2004 09:41 AM
