Overheating
Old Jan 6, 2006 | 05:35 PM
pi282's Avatar
Default Overheating
I installed the Injen cold air intake on my honda accord 2001 lx the other day and for few hours it was ok but then after that the car over heated. i took it to the dealer and replace the tube for the coolent. but it over heated again.. so i was wondering what is going on with the car...can someone tell me what might cause this. thank u
Old Jan 6, 2006 | 05:40 PM
BLKFLSH's Avatar
Default Re: Overheating (pi282)
Did you drain any coolant out?
Old Jan 6, 2006 | 08:31 PM
Ross 2.0's Avatar
In a Junkyard near you.
Double check your install to be sure you didn't mess up the little hose that connects to your breather pipe that you installed back into the new intake (you did do that didn't you?)
Old Jan 6, 2006 | 09:31 PM
pi282's Avatar
Default Re: (MooGoCow3)
the instruction came in the box so i follow the procedures... im pretty sure i plug in the hoses in the right places.. do u think its a possibility that there is a opening in the coolant box so it leaks out.. and the fluid doesnt circulate properly.. i have a feeling it might be that or i dont know..help me out once more.. thanks..
Old Jan 6, 2006 | 09:42 PM
BLKFLSH's Avatar
Default Re: (pi282)
If you drained some of the coolant (some CAIs require this) and didn't loosen the air bleed bolt when replacing it. Air in the system can cause overheating.
Old Jan 6, 2006 | 10:56 PM
pi282's Avatar
Default Re: (BLKFLSH)
i didnt drain any coolant..could that be a problem?
Old Jan 7, 2006 | 05:06 AM
BLKFLSH's Avatar
Default Re: (pi282)
I would drain the coolant and refill with the air bleed bolt loosened (bolt on block near where the top radiator hose is). To eliminate that as the cause of overheating. Air getting trapped in the system can prevent the coolant from circulating.
Old Jan 7, 2006 | 06:10 AM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">If you drained some of the coolant (some CAIs require this) and didn't loosen the air bleed bolt when replacing it. Air in the system can cause overheating.</TD></TR></TABLE>
I've never seen a cold air intake require that. Can you explain some? It doesn't make much sense but mabye I missed the point.
weaponsgrade
14
Sep 9, 2021 06:10 PM
LSUfan71
Sep 21, 2015 11:12 AM
Ocloren
Jun 23, 2005 04:07 AM
escape2me
May 30, 2004 09:22 PM
KF_S2000
Aug 6, 2002 04:46 PM
