Odd Idle Problem
Old Jun 11, 2009 | 07:51 AM
04yfz's Avatar
Default Odd Idle Problem
When starting my accord(96 non v-tech 4 cylinder) It will idle fine, staying at higher rpms until it warms up. However, once I hit the throttle or shift into gear and then back into park or nuetral, the rpms will jump up and down. The car idles fine when I disconnect the IACV, however the idle is at about 1000 rpm on the tach, which I believe is a bit high and I can not lower the idle any lower with the idle adjustment screw, so I don't know what can be the problem?
I have tried spraying with carb cleaner and starting fluid on all the vacuum hoses and can't seem to find any leaks.
Is there any way I can discconnect the IACV and trick the computer into thinking it's still connected? Just so I can pass inspection? The only reason I failed was my uneven idle.
I also pulled the ECU fuses yesterday to reset it and let the car learn the idle, it idled fine for over 20 minutes however as soon as I went to change the gears it started bouncing up and down again once it was in park again.
Old Jun 11, 2009 | 08:47 AM
Pauly321's Avatar
Default Re: Odd Idle Problem
I am not sure if this is the same problem that I was having, seeing as though mine would jump right when you started it up. What I did is take the FITV (Fast Idle Thermo Valve) off the car, there is a screw inside it that you have to tighten. This fixed my problem, when I started my car cold before the fix it idled around 3k or more now its down to 2k or below. Here is a link to the DIY to fix the problem. The pictures aren't here but I am sure you can figure it out.
https://honda-tech.com/forums/tech-misc-15/surging-idle-how-tech-article-56k-beware-1003988/
Old Jun 11, 2009 | 09:55 AM
04yfz's Avatar
https://honda-tech.com/forums/showthread.php?t=1003988
Thank you for your input, unfortunately I have already done that as well. I believe the FITV valve is functioning fine as the car idles around 2k when cold and gets lower as the engine warms up.
Old Jun 11, 2009 | 10:12 AM
whitewonder's Avatar
did you do a timing belt change recently ?
Old Jun 11, 2009 | 02:11 PM
04yfz's Avatar
Nope, it's not the timing belt. I actually figured it out after doing some more searching online. I disconnected the IACV and knew my base idle was too high so I figured I had a vacuum leak, turns out that it was just my idle being set too high. I was adjusting the wrong screw(throttle stop), instead of the flathead idle speed screw that was hidden. Passes inspection and everything is good.
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
99d-series
May 18, 2009 04:51 PM
raene
Nov 7, 2002 08:21 PM
diLUDEd
Aug 22, 2002 10:08 PM
