is this a obd2 dizzy?
Old May 3, 2014 | 03:25 PM
wwolf771177's Avatar
Default is this a obd2 dizzy?
The plugs on the dizzy (pictured below) look different than the plugs in my 94 lx.
Old May 3, 2014 | 04:10 PM
djkurious's Avatar
Default Re: is this a obd2 dizzy?
Obd1. Obd2 started in 96.
Old May 4, 2014 | 03:36 AM
GhostAccord's Avatar
Yes it very well could be. That is the exact same plug setup that was on my OBD2 96-97 Accord EX (CDN) w/F22B2. It used the external ignition coil.
The '94 would have more wires coming out of the distributor as the TDC & CKP sensors were also located in the distributor. Were as on the OBD2 those two sensors were located down behind the crank pulley & drive gears mounted to the oil pump housing.
Old May 4, 2014 | 05:55 AM
Thanks. Your exactly right. This is from a 96-97 accord non vtec.
ek2k
Oct 18, 2004 08:46 AM
gtowni3
Oct 9, 2004 09:54 AM
Turboteggy
Jul 21, 2004 08:40 AM
specie
Jun 14, 2004 06:32 PM
