NEED SOME HELP PLEASE
Old Jul 9, 2008 | 10:34 AM
ntenseaccord's Avatar
Default NEED SOME HELP PLEASE
i got a friend with a 95 honda accord, and he says that theres a winding noise when he driveing also when it's in park and the motor is reved. A mechanic told him that it might be the lower bearings?
Old Jul 9, 2008 | 12:00 PM
accord99power's Avatar
Default Re: NEED SOME HELP PLEASE (ntenseaccord)
a bad tire will have a winding noise too, if its the same noise im thinking your asking about. rotate tires first and see if noise moves.
Old Jul 9, 2008 | 12:28 PM
Default Re: NEED SOME HELP PLEASE (accord99power)
wasn't the tires cause when the motor was reved in park from the throtle link you could here it.
Old Jul 9, 2008 | 01:09 PM
SpazMan's Avatar
This is one of those things like you hear on Car Talk.
Try to narrow down what part of the engine it's from. It may well be a bearing, or a $30 timing belt tensioner. Regardless, it's sort of urgent to find out what it is. Squealing can be from:
Water pump
Tensioners
Bearings (scary)
Camshaft (also scary)
Any belt
Any belt pulley
Harmonic balancer/crank pulley
Air conditioning compressor
Try to rule out belts by spraying each with a spritzer of water, or some WD-40. Do this while the engine's running, one belt at a time.
Look at your engine's underside carefully. Any antifreeze dripping? Oil?
Let us know what you find.
Thanks,
Ari
Old Jul 10, 2008 | 12:14 PM
Default Re: NEED SOME HELP PLEASE (SpazMan)
gonna give it all a try this weekend. thanks for the info.
pmars
Jul 21, 2012 08:40 PM
92coupe
Dec 17, 2008 12:08 PM
Benhawk
Jan 18, 2008 04:40 AM
hybrid1990crx
Sep 18, 2006 06:25 AM
