need help
Old Apr 10, 2013 | 06:36 PM
rodney88's Avatar
Default need help
I'm in desperate of some help just did an engine swap to my 94 accord nothing crazy just went from the stock f22b2 to the b1 and converted the trans from auto to manual but it won't start I had a donor car that I got all of my parts from including harness ecu linkage and pedal assembly can't figure it out any ideas?
Old Apr 10, 2013 | 06:54 PM
nus_dogg's Avatar
Default Re: need help
What does the engine do when you crank it over? Just cranks but doesn't fire up? or everything just black out when you turn the key over?
Old Apr 10, 2013 | 08:01 PM
GhostAccord's Avatar
What year is the F22B1?
If it is out of a 96-97 have you addressed the TDC & CKP sensor issue between the OBD2 engine and your OBD1 chassis?
Old Apr 15, 2013 | 06:00 AM
rodney88's Avatar
The engine is a 94 same as my car I figured out why it wouldn't crank it was the starter wire off the auto shifter needed to jump it to make contact but now I have no spark in using the ecu and harness for the b1 any ideas
Old Apr 15, 2013 | 06:16 AM
nus_dogg's Avatar
Did you connect the ground wire to the driver side of the intake mani? If it's not hooked up, your engine won't have spark.
Old Apr 15, 2013 | 05:34 PM
rodney88's Avatar
Your right man that's all it was I had it on but not tight tightened it down fired right up thank you I definitely appreciate the help
TroyH
Engine Management and Tuning
Aug 24, 2018 03:44 PM
Nismo13s
20
Oct 18, 2016 04:51 PM
shiftedrx7
Aug 4, 2012 05:31 PM
thatmexican32
Honda Civic (2001 - 2005)
Sep 27, 2010 08:43 AM
