need help!!
Old Aug 26, 2008 | 09:07 AM
mickyT's Avatar
Default need help!!
okay guys...i have a 97 accord lx sedan 5 speed. everything is fine, but after slowing down off of a highway, my left front wheel shakes and wobbles which starts shaking the car too ...i'm not sure if it is because the tires are worn out, or something with the rotors, or something else, but anyone can help me on this, much would be appreciated...thanks.
Old Aug 26, 2008 | 09:22 AM
sxm5369's Avatar
Default Re: need help!! (mickyT)
I am thinking either warped rotor, or worn tie rods.
Old Aug 26, 2008 | 10:11 AM
GhostAccord's Avatar
Default Re: need help!! (sxm5369)
Does it only happen when you have the brakes applied?
If it happens without the brakes applied that is when you look at tires and suspension parts. If it only happens with the brake applied it's usually a brake problem.
Old Aug 26, 2008 | 10:29 AM
mickyT's Avatar
it only happens when brake is applied...so i will check out the rotors, brake, and tie rods...thanks guys!
jaydm73
Feb 19, 2008 02:54 PM
skweaky
Mar 7, 2006 08:39 AM
icedlee
May 6, 2005 03:54 AM
morana622
Jan 27, 2005 11:36 AM
chingchong
Sep 17, 2002 12:53 PM
