A minor Problem
Old Mar 22, 2009 | 01:10 PM
'96 CD7 accord's Avatar
New User
Default A minor Problem
I have a 96 accord(cd7) coupe and am looking at buying an Invidia cat back exhaust. I already have and AEM cold air intake, the car is dropped 2" with tokico shocks and struts and it's siting on 15" motegi r7's. Everywhere I look online, it says that the exhaust is for a 94-97 cd6 accord 2 or 4 door. Does anyone know if an exhaust for a cd6 will fit on a cd7 or not? please explain. Thanks for the help.
Old Mar 22, 2009 | 02:00 PM
locosiete's Avatar
Default Re: A minor Problem
i don't see why not but than again i'm no expert
Old Mar 22, 2009 | 02:06 PM
The-Kid's Avatar
Taken from the hondaswap.com site...
5th Gen
94-97 Sedan V6 - CE6
94-97 Sedan - CD5
94-97 Coupe V6 - ???
94-97 Coupe - CD7
94-97 Wagon - CE1
You should be just fine.. Same generation. I think CD6 is the Japanese sedan chassis code.
Old Mar 22, 2009 | 09:50 PM
New User
Thank you The-Kid. I believe you are correct. Just want to be sure, so I did some more research and found out some details on the chassis code. The CD6 is for 94-98, 5th gen, Sedan, 2.2L H22A. The CD7 is for 94-98, 5th gen, Coupe, 2.2L F22B. I am still looking for some advice. Will an exhaust for an h22 engine fit a f22 engine? Will an exhaust for a coupe fit on a sedan? Any help is very appreciated. Thanks.
Old Mar 23, 2009 | 11:47 AM
Brad_and_the_acc's Avatar
First of...
CD6 is JDM ONLY
CD7 USDM coupe
CD5 USDM sedan
^^^^^-could have them mixed up (CD5andCD7)
H22 header on F22... different exhaust pattern if I remember right.
H22 Exhaust on F22... You should be able to make it work with no problems.
Coupe pipes on Sedan... The coupe is a little shorter, so I would imagine they wouldn`t be long enough. By a few inches.
96H22CD7
Sep 17, 2007 05:05 PM
civperc
Nov 21, 2003 08:20 AM
