MAP sensor code
Old Dec 21, 2006 | 08:44 PM
Corruption's Avatar
Default MAP sensor code
Hey guys, my 01' accord is throwing a code for the mass air flow sensor and I'm trying to figure out if A. Where it is, B. If it could be cleaned and that would solve the problem, or C. I need a new one or something. Could anyone give me any clue? I'm a n00b...thanks
Old Dec 22, 2006 | 06:35 AM
Corruption's Avatar
bump
Old Dec 22, 2006 | 06:51 AM
Homesickelian's Avatar
Default Re: (Corruption)
If I'm right its right on top of your throttle body or intake and is really small. Its a sensor not a valve so it isn't exposed to crap. If yours is similar to the 5th gen it should be really easy to take care off. Just undo 2 screws.
Old Dec 22, 2006 | 11:07 AM
hondadude's Avatar
Default Re: MAP sensor code (Corruption)
Whats the code?
V6?
Manifold Absolute Pressure sensor?
Modified by hondadude at 5:46 PM 12/22/2006
Modified by hondadude at 6:26 PM 12/22/2006
Old Dec 22, 2006 | 02:17 PM
Corruption's Avatar
Default Re: MAP sensor code (hondadude)
I'd have to go up to work to figure out what the code is to be sure, so i guess ill have to do that soon
Old Dec 22, 2006 | 03:13 PM
hondadude's Avatar
This is the best I could do without having more info;
http://members.troublecodes.ne...4.pdf
Old Dec 22, 2006 | 03:56 PM
Corruption's Avatar
Is this a part that I need to be worried about getting fixed or what?
Old Dec 22, 2006 | 06:09 PM
Uh if thats what your asking about and your code is giving, yes. Do you have a V6, because if not, that might not be the same reason
your MAP is dysfunctional.
Old Dec 23, 2006 | 06:03 AM
Corruption's Avatar
no i have an i4, any idea how much this thing may cost me and if there's anywhere else I could get it other than through honda?
Modified by Corruption at 11:40 AM 12/23/2006
Old Dec 23, 2006 | 08:18 AM
come on, look for yourself, there are places that sell parts online.
Not sure about this one but its a start:
http://catalog.drivewire.com/d...ensor
Most seem to be 60-70$
Old Dec 23, 2006 | 08:29 PM
hondaccord's Avatar
Default Re: (Homesickelian)
the map controls your fuel curve depending on the incomeing air pressure. if it is sending a code it is most likely running hell a rich in defualt mode.
Old Dec 24, 2006 | 05:10 AM
Corruption's Avatar
so im guessing it's fairly easy to replace?
Old Dec 24, 2006 | 08:03 AM
look for yourself, I told you it's right on top of your throttle body. Look at a diagram online if you need it.
Old Dec 24, 2006 | 02:30 PM
hondaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption &raquo;</TD></TR><TR><TD CLASS="quote">so im guessing it's fairly easy to replace?</TD></TR></TABLE> yes it should be two screws monting it on top of the throtal body.
SoHc94
Sep 11, 2006 08:58 PM
D C 5
Jun 19, 2005 11:01 AM
accord0494
Mar 4, 2005 04:47 PM
ILLICON3000
Aug 4, 2004 03:25 PM
k4ff1n3
Sep 28, 2002 12:15 PM
