LED conversion Help
Old Sep 11, 2003 | 06:38 PM
advan's Avatar
Default LED conversion Help
so i am changing the bulbs in my doors right now in my 02 sedan to leds. i got all my materials; 470Ohm resistors, my LEDs, an iron solder and i am at a stop because i do not know which lead on the LED to solder the resistor to, is it to the anode side (+) ? And when i do that how do i hook it up to the power source to get it lighted up?
EDIT: and how do i get that bulb and socket out of the door side!!
Modified by advan at 10:52 PM 9/11/2003
Old Sep 12, 2003 | 12:10 AM
soysauce021's Avatar
if this is the lower bulb at the doors, the cover just pops off with a flat-head screwdrive and the bulb pulls out.
can i ask why you're going thru all this trouble tho?
Old Sep 12, 2003 | 12:37 AM
KTeller8's Avatar
Default Re: (soysauce021)
LED = HP
j/k. pull of plastic and paint it
Old Sep 12, 2003 | 06:32 AM
rage237's Avatar
here this should help
http://lsdiodes.home.comcast.net/circuitry.htm
if not e-mail me and i can help you out
Old Sep 12, 2003 | 09:15 AM
advan's Avatar
Default Re: (rage237)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rage237 &raquo;</TD></TR><TR><TD CLASS="quote">here this should help
if not e-mail me and i can help you out</TD></TR></TABLE>
ty man that helped a lot, i think i got it now.
im doing this just for the learning experience and to make my car less boring.
its really not hard at all, maybe less than 30 minutes if you have all the materials.
Modified by advan at 4:03 PM 9/12/2003
Old Sep 12, 2003 | 03:42 PM
advan's Avatar
Default Re: (advan)
ok new update, i tried to install the lights and then it blew the fuse for all the courtesy interior lights. now after i fixed it with a replacement fuse, i am asking what was the problem? was it my resistor? and how many volts is the power source? one person told me to wrap up all the naked wires with electrical tape, is that the waY?
Modified by advan at 8:44 PM 9/12/2003
Old Sep 13, 2003 | 02:10 PM
advan's Avatar
Default Re: (advan)
nm i got them, i wrapped the wires in electrical tape, took the fuse out then installed now they work fine!
iridebiketrials
Jun 20, 2004 07:35 PM
Nighthawk GS-R
Sep 24, 2003 12:34 AM
kana
Jun 6, 2003 02:23 PM
spoonfed95
Mar 14, 2003 02:55 PM
SonicGSR
Feb 5, 2002 05:18 AM
