Key programming required?
Old Aug 25, 2013 | 09:20 AM
ymw321's Avatar
Icon2 Key programming required?
I have a 13 year old Accord and one day both keys refused to turn (the black ones. and since I was outside I did not have the gray key with me). I towed it to the mechanic. He took the column out and replaced the worn pins. All the keys are still intact. He then told me, other than his labor cost, he needs to charge me $100 for programming the keys by Honda.
My question is, if the keys are not replaced, why would they need to be reprogrammed?
Another problem: while the two black keys now work, the spare gray key would not turn since it is a thicker key. The mechanic did not ask for the gray key and he did know about it. Does this mean the cylinder takes two sets of pins?
Thanks in advance for any advice.
Old Aug 25, 2013 | 11:22 PM
holmesnmanny's Avatar
Default Re: Key programming required?
http://www.hondata.com/immobilizer.html
The transponder codes in the keys must match the codes in the immobilizer and match the codes in the ECU for the car to start
It sounds like he replaced the immobilizer system itself. This means he does need to reprogram it. $100 sounds fair.
mmn
Jun 12, 2018 07:33 PM
hank mccoy
Aug 13, 2017 08:29 AM
moparguy
Aug 20, 2015 01:50 PM
01bb6boy
Jun 14, 2011 07:46 PM
