Jerking in between shift sequences
Old Feb 15, 2020 | 06:02 PM
Willk1969's Avatar
Default Jerking in between shift sequences
My 2002 Honda Accord jerks in between gear changes.
Old Feb 16, 2020 | 07:36 AM
99stockcivic's Avatar
Default Re: Jerking in between shift sequences
First thing is check the fluid level of the transmission. Make sure it's where it's supposed to be. Second is to make sure it's not burnt or black (should be red).
After that it gets more difficult. if you just want to try things, the next step would be to remove the shifter solenoids and clean them, the filters often are filled with junk and need cleaning.
That's where I would start.
Old Feb 18, 2020 | 03:12 AM
Aries Abuan's Avatar
I have the same issue on my accord 98. I have changed the sparkplig wire and put in new spark plugs. Now my car runs as smooth as butter.
JVM1120
Dec 29, 2019 01:35 PM
tietie
Apr 18, 2017 03:15 AM
