jdm engine
Old Sep 28, 2006 | 10:14 AM
91akkord's Avatar
Default jdm engine
if i got jdm h22a engine for my accord, what all would i need to change on the engine before i could put it in my car? i've read where you can't use the intake or exhaust manifolds, but i don't see why not. and anything else i might need to know would be appreciated, i'm new to all of this stuff. thanks alot
Old Sep 28, 2006 | 10:16 AM
iam7head's Avatar
Default Re: jdm engine (91akkord)
the intake box might not fit, but any aftermarket intake will do.
the exhaust end is neither too long or too short, so it will not be a direct fit.
but if you can swap it yourself, it's a minor problem
Old Sep 28, 2006 | 10:18 AM
EvenStar's Avatar
Default Re: jdm engine (iam7head)
is h22a actually better than the f22ab2 and b18c1 motors?
91akkord's Avatar
thanks alot!
Old Sep 28, 2006 | 11:37 AM
91akkord's Avatar
does anyone make a header or intake that is specifically for this swap? or would any after market header and intake work?
Old Sep 28, 2006 | 02:19 PM
Black Ex Coupe's Avatar
I think you have to use a usdm fuel rail because the jdm one is on the other side, but the f22 rail should work fine.
Old Sep 29, 2006 | 08:20 PM
SneezinCD5's Avatar
Default Re: jdm engine (EvenStar)
Hell no! F22 all the way!! H series have nothing on the f series. The F series is supposed to be one of the best motors Honda has.
Old Sep 30, 2006 | 04:42 AM
HondaccordH22aJdm's Avatar
Default Re: jdm engine (SneezinCD5)
haha dude! h22a all the way! well thats just me.
if u want to do the swap then its fine..
but just to let u know the motor sits further back into the enginebay.
also i would recomend taken off the vavles underneth the intakemani.
since it opens when you hit a certain rpm.
it restricts air flow taken this out is no problem.
also for the exhoust question.
just have any ordenary headers and weld a straight pipe connecting it to the rest of ur exhoust.
Old Sep 30, 2006 | 01:33 PM
91akkord's Avatar
Default Re: jdm engine (HondaccordH22aJdm)
would my tranny work with the h22? i found another swap thats about $400 less but its an auto.
Old Oct 1, 2006 | 05:35 AM
i belive so.
the h22a motor and the f22b1 auto or manuel trans are interchangable.
Old Oct 1, 2006 | 08:10 AM
xamraci's Avatar
You dont need to change your fuel rail over either...Common Misconception. I de-activated my IABS(the VALVES{they arent valves}in the intake manifold). Remove the top of the intake maifold and remove the entire system and use a longer bolt and you are done. Make sure the diaphram on the drives side of the motor is unscrewed also.
The F22 trans will fit ont he h22, however your gearing is going to be all tweeked and the car will not be as fast as it would with the H trans. Its a matter of an economy transmission with longer gears and a sport transmission with shorter gears. Any intake will fit, you will have to weld a pipe from any aftermarket header as earlier stated. I suggest changing the water pump, oil pump, timing belt, tensioner(or converting to the H23 manual tensioner if you are going to be doing any head work, IE decking ect...as a manual tensioner would be better if you altered any of your factory clearances.
Dont cheap out and NOT change your water pump, timing belt, oil pump, balncer belts, ect...it will cost you in the long run...If you dont run the EGR, or IABS you dont have to conver much on the wiring harness if you already had a vtec harness in the car...if you didnt you will just have to run a wire from the vtec silenoid to the harness and it should be pretty plug and go.
If you arent familiar with swaps and so forth...you really might want a shop to do the swap, in saying that...you want a shop that knows what they are doing...
k24CivicHatch
May 15, 2010 01:18 PM
SkRiBLaH
Apr 2, 2010 06:24 AM
91akkord
Sep 28, 2006 08:49 PM
juelz111
Aug 28, 2005 09:16 PM
illusion
Oct 3, 2001 10:56 AM
