Idle problems
Old Mar 9, 2007 | 10:27 AM
Jstitch's Avatar
Default Idle problems
Well we cleared the codes finally and when we turned it on last night it sounded good but when we reved it up a little and let of it started to idle higher and higher and we finally cut it but it was reaching like 4000 rpm
Old Mar 9, 2007 | 10:32 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Idle problems (Jstitch)
I know users can just search for your thread about your codes to find out what car you have but you should really make it a point to say what year/model car you have and what swap if any. It's makes it quicker and easier.
Old Mar 9, 2007 | 11:57 AM
Jstitch's Avatar
Default Re: Idle problems (TouringAccord)
Sorry about that i have a 94 ' accord Ex and we are swapping a JDM H22A 94' prelude motor in and i am having the problem stated above. We just got through clearing the codes.
Old Mar 9, 2007 | 12:09 PM
Accord2k-Hybrid's Avatar
an air leak can cause idles that high, but you would be able to hear it if you payed attention to the intake manifold.
Edit: check your throttle as well, your throttle could stick and you might not know it, pull off the intake pipe and watch the throttle. if that's not stuck then I stick to my previous statement. It could also be the IACV or FITV.
Modified by Accord2k-Hybrid at 1:49 PM 3/9/2007
mikelesnick
Aug 7, 2018 02:05 PM
michaelsej1
18
Feb 21, 2011 07:13 AM
Cuda
Apr 17, 2008 08:40 PM
SoHc94
Mar 15, 2007 09:33 PM
vtec94civic
Aug 9, 2005 03:35 PM
