HELP...
Old Aug 10, 2004 | 01:50 PM
duanem's Avatar
Default HELP...
I did a compression test on the cylinders. Put the plugs back in and tried to start it and now it will not start. Any ideas?? It is a 90 honda accord ex
Old Aug 10, 2004 | 03:23 PM
madd's Avatar
Default Re: HELP... (duanem)
did you unplug the distributor? (the center wire that goes to the distributor that is)
Old Aug 10, 2004 | 04:08 PM
duanem's Avatar
Default Re: HELP... (madd)
Actaully fixed it. It ended up being the ignition coil. So that was a$100 lesson. It must have happened when i was checking the compression.
Old Aug 10, 2004 | 04:53 PM
earthworm's Avatar
Rather hard to believe, maybe it could happen. The powerful spark has no place to go and burns out the coil ???
The coil should be disconnected at the primary side. Which no one ever bothered to do, including me....
When checking compression I would make certain that the transmission was in neutral (it was possible to do this from under the hood!) and then , with my switch and two leads with alligator clips, engage the starter motor as necessary..
Those were the "good old days"......
4 door beast
Mar 16, 2012 03:55 PM
KayTran
May 12, 2008 09:59 PM
andyt
Jan 7, 2006 10:39 PM
Stick2shiFTN
Oct 12, 2005 12:14 PM
pootie.teng
May 27, 2005 08:56 PM
