HELP!!!
Old Jul 17, 2001 | 08:11 AM
accord4banger's Avatar
New User
Default HELP!!!
i hav a 97 accord...i hav skunk2s in them.....ride is TOO FREAKIN bouNCY! wut should i do??? i bottom out lotta places n tires scrape under the undergrill part or wutever its called....if i got a camber kit, would it help reduce the bounce alot, lil, or so so? n wut kinda shocks would fit wit the skunk2s...thanks
Old Jul 17, 2001 | 09:24 AM
Boughetto's Avatar
New User
Default Re: HELP!!! (accord4banger)
I have Ractive coils on my Accord. I know exactyl what you mean, I boucne around more than a kid on a trapoline! I am switching thm out for Eibach Pro-Kits. I will eventually change my shocks and struts. Damn it sucks now!
Old Jul 17, 2001 | 10:07 AM
SOHCArchangel's Avatar
Default Re: HELP!!! (blue95accord)
you will need stiffer shocks, to keep up with that spring rate, of course its gonna be bouncy if you are using stock shocks b/c nothing is dampening the rebound enough
Old Jul 17, 2001 | 12:09 PM
New User
so....its better to jus switch to like springs instead of gettin shocks n keepin the coilovers?
Old Jul 17, 2001 | 12:28 PM
Dropped's Avatar
New User
Bro You diffentatly need some aftermarket shocks. Check out Tokito (mis-spelled). But it will help out allot versus your stock OEM shocks. I had the same problem on my LUDE.
Basically what is happening is you probably got it down to where you are maxing out the strut and causeing to to not have resistance ,, so its just working your spring ONLY. I bet IF you look under the wheel well and look at the shock,,, I bet its leaking huh??
If so, your shocks are shot and no good. So basically your ride is riding on the spring it-self.
BTW.... if you decide to put a regular new set of OEM struts.. they will be shot out in no time and they will not be good idea. Do it right man!! Get aftermarket lowering shocks/struts.
Old Jul 18, 2001 | 12:48 PM
m0t0rhead's Avatar
Progressive rate springs (like Eibachs or Neuspeeds) are a nice combo with coil-sleeves and adjustable shocks.
Less bounce, more control.
I have my tokico's on setting 5. The hardest. Barely any bounce at all..
Old Jul 18, 2001 | 04:49 PM
Honda318dx's Avatar
haha... Get some shocks and cut your bump stops.. KYB AGX is the way to go.. Great price and better than tokicos IMO>>
Old Jul 18, 2001 | 07:04 PM
New User
thanks for all the tips all
ev_ez
Mar 29, 2006 08:21 PM
aleks77
Aug 13, 2005 02:38 PM
alex01
Aug 25, 2004 12:00 AM
prelude93si
Aug 10, 2003 06:13 PM
Kloud
Dec 26, 2001 06:15 PM
