Help!
Old Jan 19, 2024 | 05:28 PM
TacomaBud's Avatar
Default Help!
So this is the problem. Just bought a 93 accord. Starts right up first try when cold. After running the car to normal operating temperature when I shut it off it will not restart. It will just crank and crank. It's been like 35 degrees outside, I did resolver the main relay anyway but I don't think that's the problem. To summarize starts right up when cold, after engine is warmed up just cranks and cranks. I work on cars and have had a bunch of preludes and acura legends...just can't figure this problem out. Thank you in advance for any help, thanks.
Old Jan 19, 2024 | 10:01 PM
Micro1989lxi's Avatar
Loved
Community Favorite
Default Re: Help!
Is the fuel pump working when it won't start?
Does it have spark, is it a bad ignition module or coil?
Old Jan 19, 2024 | 11:55 PM
TacomaBud's Avatar
Default Re: Help!
Well I can hear the fuel pump prime everything, doesn't mean it's getting fuel to the motor. But as I said when the motor is cold fires right up first time. I let it run and get warm turn it off, just cranks. And do all 90-93 accords have the coil inside the distributor? This one has a td52 distributor with an external coil.
Old Jan 20, 2024 | 04:52 AM
LukeM's Avatar
5 Year Member
Default Re: Help!
No, F22A engines in North America have external ignition coils. Start googling your problem, you're not the first.
charlesg22
Other Make Vehicles
Feb 4, 2023 02:27 PM
2002HondaAccord
Jul 18, 2015 11:46 PM
eshaktman
Aug 3, 2011 03:44 PM
bimmeracer
Feb 11, 2008 10:19 AM
sd93accordex
Dec 7, 2005 03:27 PM
