Help
Old Sep 16, 2016 | 09:08 AM
R3DSOX96's Avatar
Default Help
Hi new here i have a 96 honda accord lx coupe
Have a emission code P0441. what are those common problem before i take it to honda ..
Old Sep 16, 2016 | 10:36 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Help
P0441 EVAP Emission Control System Improper Purge Flow
Verify your gas cap is properly installed.
Verify the gas cap seal is not damaged or missing.
Verify the purge valve is properly connected.
Verify the vacuum hoses are attached correctly
Backprobe valve with meter and verify correct voltage.
If any work has been done recently on the car recheck that work first.
Old Sep 16, 2016 | 11:39 AM
R3DSOX96's Avatar
Default Re: Help
Thanks
I have done some work recently,had a code P0420 also,so i replace the catylic converter and catback that code went away.
brad8266
Jul 12, 2022 10:28 AM
learnonmyown
Sep 15, 2014 05:35 PM
jorge99hx
13
Nov 9, 2007 05:24 PM
JDMN
Mar 4, 2007 07:27 PM
SIMATIC
Sep 26, 2004 04:29 AM
