Headlight issues
Old Jan 21, 2008 | 07:32 AM
propwdialogue's Avatar
Default Headlight issues
So as its gotten colder, I've been having some problems with my headlights. There was a delay between when I flipped them on and when they actually turned on and sometimes they would flash on and off for as long as five minutes before they stayed on constantly.
Now, they will not turn on at all. My driving lights turn on fine and my turn signals work normally. Also, when my headlights turn on, the brights will not flip on either.
I have it narrowed down to either the switch or the relay. Any guesses as to which is the problem?
Also, the relay for the headlights is not labelled as such in any documentation I've seen. In the picture below, I jiggled all the relays and #18 caused my headlights to flash (back when they would still turn on), so I assume this would be the correct one to replace. Has anyone else had this issue, and what did you do to fix it?
Old Jan 21, 2008 | 07:47 AM
Default Re: Headlight issues (propwdialogue)
Also, if anyone has the wiring schematic for the headlights (even the one from a haynes /chilton manual will do), it would be greatly appreciated if you could post it, my service manual and I are in different cities
Old Jan 21, 2008 | 08:24 AM
TheMuffinMan's Avatar
He knows where you live!
As you said, I would imagine it'd be the relay or the switch.
Have you tried replacing the control stick on the interior? That you could test fairly easily (just grab a used one or borrow a friends) and quickly swap them to see if it works or not.
Alternatively I believe there's a relay and two fuses (one for each light) in the under the hood box as you described.
What happens if you jiggle with it now? If nothing happens I'd say that guy is toast (The relay) I had similar symptoms with my fog lights and tracked it down to everything being correct save for the relay - bought a new one and bam! They work every time now.
Old Jan 21, 2008 | 08:39 AM
Default Re: (TheMuffinMan)
Yeah, I've tried jiggling it now, and it doesn't do anything...head to the dealer and pick up a new one?
Old Jan 21, 2008 | 08:56 AM
dealer or pick and pull
My guess is that relay is just toast - did you see any moisture in it? That ended up being my problem - it had rusted the terminals and busted it.
Old Jan 21, 2008 | 09:36 AM
Midori Bandit!'s Avatar
yeah id say head to a junk yard and pick one up.
Old Jan 21, 2008 | 11:37 AM
Default Re: (Midori Bandit!)
Went to my local junkyard, and picked one up for 3 bucks, fixed my issue!
Old Jan 21, 2008 | 12:15 PM
Default Re: (propwdialogue)
Glad it worked for ya man
Junkyards = awesome
Morlow
10
Dec 15, 2010 06:28 AM
fire21
Oct 15, 2007 02:24 PM
Chewy Built !
Oct 4, 2006 08:26 PM
Finest
Sep 12, 2002 06:12 AM
