h22a engine question
Old Dec 13, 2002 | 01:13 PM
pisces21's Avatar
Default h22a engine question
Hey guys,
I'm gonna get a h22a prelude engine (decided to stick with the accord for all you that responded to my rsx or accord thread). Now i'm gonna turbo charge it, so should I get the type s engine which has 20 more hp over the regular h22 engine. I heard if i'm turboing it to just get teh regular engine (200hp one)..any facts, comments, opinions, professional advice, etc. would help. thanks!
Old Dec 13, 2002 | 01:25 PM
GZERO's Avatar
Default Re: h22a engine question (pisces21)
Hey guys,
if you are going to turbo charge or supercharge it stick with the normal H22A, but my suggestion would be turbo charge the F22B, and if you are going to build it, build the F22B as well, the limits of turbo chargin on the H22A could be higher, but the F22B will give you lots of torque which are needed to move our fatty accord.
Old Dec 13, 2002 | 02:23 PM
Sinisterh22a's Avatar
Hey guys,
het the reg one what makes the type s have more power is the head(cams, and intake manifold) the valves and retainers are better as well but the main thing that gives it more power is the pistions they are higher compression if your gunna be stock and turbo it turboing the type s you will have to run lower boost
Old Dec 13, 2002 | 05:14 PM
pisces21's Avatar
Default Re: h22a engine question (Sinisterh22a)
thanks for the advice guys!
Old Dec 13, 2002 | 05:18 PM
GZERO's Avatar
what are you doing then? i strongly suggest the turbo F22B
Old Dec 13, 2002 | 05:30 PM
Nick M's Avatar
Default Re: h22a engine question (GZERO)
I suggest you do a search
Old Dec 13, 2002 | 07:01 PM
ViZ's Avatar
ViZ
Default Re: h22a engine question (Nick M)
or an h23 its good for boost also.. the prelude forum has a really good thread that is ongoing about turbo in the h series
https://honda-tech.com/zerothread?id=316373
Old Dec 13, 2002 | 07:57 PM
pisces21's Avatar
Default Re: h22a engine question (ViZ)
i alot of ppl here say to go h22 w/ turbo.....not too many says to go with the f22 here....considering i have 101k on it and its been beaten badly by my grandfather when he got the car new.
Old Dec 13, 2002 | 08:28 PM
ricepicker's Avatar
Or you could always get the H23
Old Dec 13, 2002 | 08:31 PM
GZERO's Avatar
ok, yes, but look at this
H22A(which you don't know how many miles or condition is)+instalation (if you decide to pay for that)+turbo kit= +-6k
F22B (free) +turbo kit= +-3K (it will last a while till you have to rebuild it)
and if you decide to rebuild
F22B(free)+golden eagle sleeves+pistons+rods+turbo= +- 5K
lot's of torque= PRICELESS!
EDIT: F22B engines have a strong reputation of being really strong and good for boost, it has a long stroke ratio which equals to higher torque, but not good for high RPMs, but with a turbo you don't need high RPMs
[Modified by GZERO, 12:34 AM 12/14/2002]
Old Dec 14, 2002 | 12:34 PM
pisces21's Avatar
hey thanks for the advice zero....something to think about
Old Dec 15, 2002 | 12:37 PM
GZERO's Avatar
no problem
Old Dec 21, 2002 | 06:30 PM
mugenbb6's Avatar
I guess you've never turbocharged an h22 before. Why are you recommending the f22b? Comon, SOHC vs. DOHC???? DOHC makes a big difference. Here's my advice. Save up a lot of money. Buy an H22a, have it built up, and then put it in your car + turbo.
Old Dec 21, 2002 | 06:35 PM
niedejb's Avatar
Default Re: h22a engine question (mugenbb6)
This is where you lost me.....the H22 will cost what a turbo kit would cost if not more.
You know my opinion on the matter.
Old Dec 22, 2002 | 06:33 AM
AccordDriver92's Avatar
Stick with the normal H22
Old Dec 22, 2002 | 08:23 PM
Illtal's Avatar
I've had a NA h22 and a boosted F22 i say so with the h22 boosted
Old Jan 1, 2003 | 01:39 PM
ColdAccord's Avatar
Default Re: h22a engine question (ricepicker)
h23 if you're going turbo
Heliattack
Sep 16, 2008 01:40 PM
OOSpyder85
May 25, 2006 09:17 AM
.:Swig:.
Apr 19, 2004 11:18 PM
RotiEatter
Feb 7, 2003 06:04 PM
rich
Apr 10, 2002 03:49 PM
