2000 Accord Question? Thanks guys for your expert input....
Old 03-23-2007, 12:07 AM
lonebun's Avatar
Default 2000 Accord Question? Thanks guys for your expert input....
question for all you guys, my 2000 Accord when goes only over speed bumps or dip on road make a noise from left wheel side of car and not on any other. Is it the shocks or other (springs)? Do I need to change it & how much is it to change? I really don't know to much about car...needs help....thanks for all your input
Old 03-23-2007, 06:53 AM
jdmarzan671's Avatar
Default Re: 2000 Accord Question? Thanks guys for your expert input.... (lonebun)
could be the shocks.
It shouldn't cost so much to replace em. You can even do them yourself. Patience and a good write up is key to a DIY!
Good luck!
Old 03-23-2007, 12:22 PM
02 accord's Avatar
How many miles on the car? It could be bad ball joint(s).
Old 03-23-2007, 04:51 PM
philadd's Avatar
Default Re: 2000 Accord Question? Thanks guys for your expert input.... (02 accord)
There are so many things that can causes noises... shock, spring, bushings, sway bar link, ball joint, etc.
Old 03-23-2007, 05:09 PM
Heat's Avatar
Describe the noise.
Hondapreludeg
11-05-2023 02:21 PM
ujhonda
04-26-2009 04:56 AM
AmyJ
06-17-2008 04:39 PM
Quick Reply: 2000 Accord Question? Thanks guys for your expert input....
