H22 has issues
Old Jun 18, 2012 | 07:13 PM
Thepowderblue's Avatar
Default H22 has issues
I have a Cb7 with a h22a4 ran by a P0F ecu with obd2 h22 injectors.
It has no CEL.
It dies at idle after its wormed up. Its lacking power and running with a little bit of a miss. Vtec wont engage and it cuts out at 6500
Any ideas?
Old Jun 18, 2012 | 10:47 PM
holmesnmanny's Avatar
Default Re: H22 has issues
did you delete the resistor box ?
Old Jun 18, 2012 | 10:52 PM
As in cut it off and twisted all the wire together yes.
Old Jun 19, 2012 | 12:37 AM
I'm not sure about the P0F, if the pins are different than the P13 ecus. I know the obd2 injectors don't use the resistor box.
Old Jun 19, 2012 | 12:59 AM
A pof is a p13 but it came in jdm accord SIR's
Old Jun 19, 2012 | 11:47 PM
Bump, does it sound like a issue with my dizzy? I ordered one but it wont be here for a few long days.
Old Jun 20, 2012 | 07:17 PM
Anyone? Does it sound like a coil?
Old Jun 20, 2012 | 07:35 PM
JuicedUpRice's Avatar
it does sound either distributor/ignition or ecu related.
Old Jun 20, 2012 | 10:13 PM
Not sure how accurate this is but
http://nzhondas.com/tech-help/89192-...f-903-ecu.html
post number two
Old Jun 21, 2012 | 02:10 PM
v4lu3s's Avatar
RTFM
what is it idling at? is timing correct (both mechanical and then ignition)?
Old Jun 21, 2012 | 02:37 PM
97acclude's Avatar
A fitv will cause it to stall out like that or a iacv. Try taking them both off and cleanin em with carb cleaner but you might want to get a new iacv gasket from honda first for a few bucks mine was pancaked when i took it off so i replaced it
Old Jun 21, 2012 | 03:59 PM
Both timing is set right and the fiv wont cause it to also run like ****.
seklze
Nov 10, 2017 04:10 AM
more3688
Mar 10, 2010 02:57 PM
on-site ej1
Dec 15, 2008 08:08 AM
bowdown201
Mar 4, 2008 07:40 PM
spoon93
Jan 25, 2008 05:25 PM
