F22a vtec conversion?
Old Mar 11, 2012 | 12:28 PM
92LXcb7's Avatar
Icon2 F22a vtec conversion?
Ok I've done research and nothing but just wondering can you convert a f22a1,4,6 to vtec? I've seen conversion kits for shock and dohc like having vtec parts and stuff like that I wanna keep the a1 head tho jw if its possible don't say I'm dumb just wanting info
Old Mar 11, 2012 | 03:00 PM
dglassmyer's Avatar
Default Re: F22a vtec conversion?
You can convert a f22ax motor to vtec but doing so requires swapping the cylinder head.
This particular swap is covered in our FAQ section.
There is no way to convert a f22ax cylinder head to be a "vtec" head though.
Vtec cylinder heads use special oil channels, lost motion devices, and rocker arm assemblies that are not compatible with any f22ax head.
In the case of the oil channels and lost motion assemblies, these are components that must be incorporated into the original design of the cylinder head as a casting.
It isn't the sort of thing you could "bolt-on" and convert.
Your best bet is to stay with the head you've got or switch to a f22a6 head, which has the most aggressive cam profile of the f22a motors.
If you really want vtec you could go with the B1 swap outlined in the previously mentioned FAQ but unless your installing head studs or have the head off for some other reason, it really isn't worth it.
I just swapped from an f22b2 to a f22b1 head on my car, as I was installing headstuds anyway and it has proven to be quite a hassle addressing the smaller issues with the swap.
Old Mar 11, 2012 | 03:03 PM
JuggerNaut-CTR's Avatar
Why convert to sohc vtec? Might as well convert it to a g22
Old Mar 11, 2012 | 03:54 PM
92LXcb7's Avatar
Ok Ty I was jw. my brother has a eg coupe ex d16z6 heads ported itm is to headers cold air intake and he beats me by a lil bit and mines stock with timing off -_- and yeah I need to fix that. and I hear alot that the g22/g23 head swap has issues.
Old Mar 11, 2012 | 04:01 PM
rx7_dude2003's Avatar
I just finished my g22 turbo setup. Its fun! N I havnt had any issues yet.. (knock on wood)
Old Mar 11, 2012 | 04:02 PM
Such as?
Only ones I have heard to have issues was from lil kids slapping a head onto the block, cheaping out as much as they can just so they can despretely get their vtec.
If you have realtively decent motor knowledge and you research before doing it, it will be problem free.
Just a suggestion, do with it what you wish.
Old Mar 11, 2012 | 04:04 PM
^^^^^ Wheres the like button???!!!
Old Mar 11, 2012 | 04:26 PM
92LXcb7's Avatar
Lol well I like the idea of h22 head on a f22 block but I'm a single slammer guy.
Old Mar 11, 2012 | 05:08 PM
Icon3 Re: F22a vtec conversion?
Eh..
Old Mar 11, 2012 | 08:38 PM
GhostAccord's Avatar
IMO the hybrid F22 block or F23 blodk w/H22 head swaps are highly overrated. If you don't mill the head or put in larger compression pistons your stuck having to boost it. After doing the swap with no mods, the compression ratio is lower than the stock F22A & B engines.
If you want VTEC the best bang for your buck is to swap in a complete H22 engine. If you want to stick to SOHC VTEC. Then do an F23A1 swap with a larger cam in it. Both of these engines fit your car with little to know physical modifications. They bolt up to your current transmission as well.
Old May 17, 2014 | 02:40 PM
grinner910's Avatar
I am really hoping to someday swap an H22 into my Accord. I am very pleased to learn that my transmission will bolt right up to it.
PushnFords
Honda Civic (2001 - 2005)
Jan 10, 2018 09:58 PM
Red-Rocket
Dec 17, 2013 03:13 AM
eg6lsv-t
Dec 20, 2009 04:26 PM
b_rush
Dec 19, 2009 01:03 PM
ImXposed
Aug 23, 2005 07:25 AM
