f22a first timer
Old Sep 18, 2009 | 06:40 PM
blackonblackprelude's Avatar
New User
Default f22a first timer
i just bought a 92 2dr with an f22a in it can any one help me on were to start on getting some more power out of the engine i would love to turbo were do i start sumone please help
Old Sep 19, 2009 | 02:44 AM
GhostAccord's Avatar
Default Re: f22a first timer
Do you know anything about boosting and engine in general? Learning the specs and limitations of your engine and knowing what turbo you wish to use would be the first step.
From what I have seen the F22A1 is fairly reliable up to 300 WHP with stock internals and ignition system, upgraded injectors and a tunable ECU w/a good tune. That being said. The engine itself has to be in good working order to begin with. Do a compression test and leak down test to ensure that your engine is in good enough shape to handle boost pressures. If you are planning to rebuild the block already than this shouldn't be a problem.
All the information you require is easily obtainable by searching/reading the Forced Induction (FI) forum. There is a lot of good information to be found in there. You will have to read a little bit to get through it all though.
91accord22l
Jun 16, 2010 04:29 PM
extra cam needed
Jun 30, 2005 07:26 PM
Catera
Feb 22, 2004 10:31 AM
elderjoe
Jan 28, 2004 05:41 PM
