engine work question
Old Mar 5, 2006 | 07:42 PM
FallenAngelHIM's Avatar
Default engine work question
can someone tell me what #9 does? what the parts improve and why they are needed? also, are they any good?
http://importperformanceparts.....html
Old Mar 5, 2006 | 08:43 PM
Dmc1's Avatar
Default Re: engine work question (FallenAngelHIM)
It's basically an overpriced engine rebuild kit.
If the pistons are good quality forged aluminiumm wisco's then it may give you a few Hp maybe 2-5.you could buy some with higher compression it could give it a little more.But if you get to high compression the engine won't even run with the stock valve train and I think you would probably run lean on fuel to.And you would need to run 93 octane all the time.
Old Mar 5, 2006 | 09:05 PM
P_Adams's Avatar
Basically you're replaceing the stock pistons with Wiseco Forged pistons. You have the option of choosing both compression Ratios and incrimental oversizes, depending on your requirements.
The Pistons/Rings and Pins are considered a "Piston Kit"
Basically everything else are high performance versions of additional parts required to successfully assemble everything back together.
This (these) lits are ordered only after all the block prep work is performed since they will need piston size (standard, .010 oversized etc) and main & Rod Bearing sizes (standard, .001, .002 .010 etc) to get you the correct stuff.
P
Old Mar 5, 2006 | 09:36 PM
Default Re: engine work question (P_Adams)
just when i fully understood the bolt-on's fully, now i have an entire new book to discover. thanks p_adams for the info. any links you know of that i can learn more about "block" work and prep?
Old Mar 6, 2006 | 05:28 AM
P_Adams's Avatar
How to Rebuild Your Honda Engine,
Author:Tom Wilson
Publisher: HP Books, US
or a Google search like:
http://www.google.com/search?h...earch
Your best bet is a shop (Service/repair manual) if you're this commited to DIY. They will have all the factory specifications you need to watch for.
The short answer to "Prep Work"? Disassembling everything, Cleaning everything within an inch of it's life (boil the block etc) measuring everything and addressing any wear found (Honing/boring cylinders, regrinding the crank (if ness) to the next standard size) ordering parts and then getting very **** about putting it back together correctly.
P
Old Mar 6, 2006 | 05:41 AM
AFAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">The short answer to "Prep Work"? Disassembling everything, Cleaning everything within an inch of it's life (boil the block etc) measuring everything and addressing any wear found (Honing/boring cylinders, regrinding the crank (if ness) to the next standard size) ordering parts and then getting very **** about putting it back together correctly.
P</TD></TR></TABLE>
Aahhh... ::runs away in fear::
Old Mar 6, 2006 | 06:50 AM
P_Adams's Avatar
Default Re: engine work question (AFAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">Aahhh... ::runs away in fear::</TD></TR></TABLE>
LOL
Hey, what would you rather I do?
Dance around the topic and tell him how it's like falling off a log; or put the topic on the table so he has a better idea what's involved?
But yeh, the vision of Macaulay Culkin with hiis hands to his face wouldn't be that far off
P
Old Mar 6, 2006 | 06:54 AM
Crono139's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">But yeh, the vision of Macaulay Culkin with hiis hands to his face wouldn't be that far off </TD></TR></TABLE>
Consider it done.
Old Mar 9, 2006 | 09:43 PM
thanks for the feedback guys
Old Mar 10, 2006 | 05:12 AM
notoriousB's Avatar
Default Re: engine work question (Dmc1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">But if you get to high compression the engine won't even run with the stock valve train </TD></TR></TABLE>
what? why not? the stock valve train would be perfectly fine with higher compression pistons if you're maintaining the stock rev limit.
you big wussies!
Old Mar 10, 2006 | 07:28 AM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">if you get to high compression the engine won't even run with the stock valve train and I think you would probably run lean on fuel to.And you would need to run 93 octane all the time.</TD></TR></TABLE>
The only issue the valve train would have with regards to high(er) compression pistons would be Valve/Piston clearance with the advent of a higher Dome. This would only come up for these reasons
1) Larger than stock (diameter) valves were installed
2) Higher than stock cam lift was present
3) Head had been shaved or a thinner Head gasket had been installed.
If the piston manufacturer is careful in his design, these are taken into consideration by incorporating larger than required Valve reliefs in the Piston crown.
Yes, higher octane fuel will be required to control detonation.
P
Old Mar 10, 2006 | 07:30 AM
Thunder Cat's Avatar
jacking this thread for a second.
hey P,when i get my 4dr teggy,will you be able to help me with how you've BEEN helping me already?
Old Mar 10, 2006 | 07:36 AM
P_Adams's Avatar
Default Re: (Thunder Cat)
I may fret ignorance from time to time, but sure - bring it on. Just be aware, I'm rapidly loose Brain Synapses from the effects of long ago Youthful Indiscretions ; so some of my responses may elicit a "What the F**k did he just say???" response.
P
Old Mar 11, 2006 | 06:24 AM
if all else fails,i guess i'll just get another honda. aslong as i get what i've been given ^_^
eddie7978
Engine Machining & Assembly
May 12, 2017 09:36 PM
cioli
May 31, 2007 02:24 PM
Hy-wind
Dec 2, 2004 04:18 AM
jap-spec
Jan 16, 2003 09:35 PM
