Engine valves causing lean condition?
Old May 30, 2018 | 02:26 AM
Hypochondriac's Avatar
Default Engine valves causing lean condition?
Can a problem with the engine valves cause a lean condition. The car is a 2000 accord, 4 cylinders with 61k miles on it. I'm still chasing a p0171 problem, was told a engine valve adjustment should fix it
Old May 30, 2018 | 08:40 AM
holmesnmanny's Avatar
Default Re: Engine valves causing lean condition?
lean normally means some sort of vacuum leak causing too much air
i would think you would have a high idle as a result
a quick search for that code turned up this
Old May 30, 2018 | 07:20 PM
https://youtu.be/IijCx5iVFCU
Idle is normal I believe. At first start it's around 1100 rpms, but then quickly lowers to ~700 rpms.
Old May 31, 2018 | 11:40 AM
this is not a very common code
if you're near a junkyard, might try another ecu
how does the car run ?
carybriel
Mar 22, 2012 07:24 PM
SlipGear
Jun 26, 2008 05:37 PM
mcm415
Mar 20, 2008 06:04 PM
peiceofshitaccord
Aug 12, 2006 11:38 AM
Eric R
Apr 25, 2003 11:20 PM
