Engine surging
Old Jul 6, 2023 | 10:18 AM
HondaReaperCG5's Avatar
Default Engine surging
I just recently replaced the transmission and motor in my 1998 Honda Accord 2.3l. Needless to say the shop did a crap job and alot of the parts didn't get replaced on the new motor. So I'm dealing with alot of sensor issues. I've got a surging issue going on. It only happens in park and neutral. Also it idles high, a little over 1000 rpms. Tried to adjust but don't seem to be working. Doesn't seem like the VTEC is wanting to kick in either. Anyone have any ideas??
Old Jul 6, 2023 | 10:55 AM
nicolaselias's Avatar
Loved
Community Favorite
Default Re: Engine surging
Speed sensor working?
Map sensor connected properly?
O2 sensors connected?
Hook up a cheap OBD 2 scanner and see what it tells you, not just codes, but in terms of the live data. Might help you narrow it down
Old Jul 6, 2023 | 11:28 AM
Yeah the speed sensor, map sensor, and O2 sensors are all plugged in. I have a scanner so I'll try the live data. All I've done so far is pull the code. P0505 is the code I'm getting, when I've researched the code it says its the iac valve needing replaced or possibly a vacuum leak. But yeah I'll try the live data and see what it tells me first.
Old Jul 7, 2023 | 05:59 AM
Loved
Community Favorite
Clean up the idle air control valve and make sure all vac lines are connected/no leaks. definitely a good place to start
Old Jul 7, 2023 | 06:17 AM
Yeah I think I'll give that a try this weekend. Been reading alot of stuff on it and that seems to be what it always goes back to. The IAC sits in a horrible spot. Do you know if it's easier to take off the throttle plate first? It seems like it would be, just didn't know if it's be opening up another issue by doing so.
Old Sep 3, 2023 | 04:39 PM
Solidify's Avatar
I'm having the same symptoms and code, did you solve yours yet? And yes it's easier with the throttle body off to access the iacv
jesser916
Honda Accord 2016- 2017
Feb 4, 2018 07:43 PM
TrpVtecChk38
Jun 5, 2017 06:25 AM
Dizzyman
Apr 11, 2013 08:10 AM
allen8908
May 7, 2009 06:20 PM
