Engine sputters on acceleration
Old Nov 23, 2021 | 10:12 PM
the_tensl's Avatar
Default Engine sputters on acceleration
I just replaced the fuel filter, injectors and cleaned the egr, but it's still having the sputter/ almost stalling when I take off, it idles fine and drives fine after it sputters and catches up l, any help please
95 accord 4 cyl. A/T
Also no codes
Old Nov 28, 2021 | 12:06 AM
brakedrum's Avatar
Default Re: Engine sputters on acceleration
If its got a lot of miles on the o2 sensor (Oxygen sensor) you may want to look at that. A weak one can cause the sputtering and bucking you are describing. I think your year has just one o2 sensor. Note that OBD-1 is not strong on showing codes for weak sensors that cause sporadic problems, however it will show a CEL when the sensor is unplugged. You could try unplugging the sensor, being sure to protect the plug from getting melted under there, and see how she runs. Only run it like that very briefly. The o2 sensor also protects the catalytic converter, the most expensive part in the exhaust system.
Old Nov 29, 2021 | 07:30 PM
the_tensl's Avatar
I have checked that could it be the IACV or FITV maybe it still randomly surges and when I turn on my lights it blows the interior light fuse
rocky2005
Aug 10, 2011 05:58 PM
vecken
Aug 23, 2009 09:40 AM
spyda man
Aug 21, 2007 09:31 AM
Casey96SS
May 8, 2004 06:40 AM
