Engine.
Old Mar 24, 2013 | 10:32 AM
BlackFlame11's Avatar
Default Engine.
I have a 97 Accord and I may have to replace the engine soon. I'm wondering what all engines will fit.
Old Mar 24, 2013 | 02:45 PM
nus_dogg's Avatar
Default Re: Engine.
Any of these engines will fit:
-F22B1
-F22B2
-F23A1/A4
You want to step it up more?
-USDM H22A1/A4
-JDM H22A
-JDM H23A VTEC
-JDM F20B
-USDM H23A1/JDM F22B DOHC
Old Mar 27, 2013 | 03:56 PM
Default Re: Engine.
I see. I'm new to the Honda world. So, I don't know what most of those are. But, I'll research them. Thanks man.
Old Mar 27, 2013 | 05:52 PM
Crxh22ajdm's Avatar
Default Re: Engine.
Jus go for the H22A etc, has about 60 more hp than your stock engine, buy it complete including tranny
Old Mar 28, 2013 | 02:31 PM
Default Re: Engine.
Any idea how hard it is to do a swap?
Old Mar 30, 2013 | 06:29 PM
nus_dogg's Avatar
Default Re: Engine.
Get a JDM H23A VTEC blue top. Has more power and torque across the powerband. Much more powerful than an H22A. But they only come in automatic though as they are from the JDM Accord SiR Wagon in Japan. So if you mate it to any H22 trans, you will see the full potential of this motor along with some nice engine mods.
Swap is simple. Get a Hasport or 93-96 Prelude timing belt side mount and the motor will bolt-in. For wiring, you want to get the same year engine to match your year Accord for simplicity. And everything will pretty much plugs in with a few wiring extended. For your 97 Accord, you'll need to get the rare USDM 96 H22A1 ECU as it doesn't have immobilizer. 97-01 does, and you won't be able to use it on your H22 setup or you can convert to OBD1 and be able to get your H22 Accord tuned to extract more power and run like how it should. And your header will need to be modified to fit your current exhaust.
Old Mar 30, 2013 | 08:09 PM
Default Re: Engine.
So... Difficult? Haha.
Old Mar 30, 2013 | 09:10 PM
NZXTInerTia's Avatar
Default Re: Engine.
Use belt side motor mount, use H22A1 transmission, drop in engine, attach wiring, tunable ECU, conversion harness. Not all that difficult.
Old Mar 31, 2013 | 05:58 AM
Default Re: Engine.
I don't know what a tunable ECU is. Or a conversion harness.
Old Mar 31, 2013 | 07:17 AM
Default Re: Engine.
My Accord is an Automatic. So, I will definitely look into that.
Old Mar 31, 2013 | 09:47 AM
Default Re: Engine.
Should look into modifying your car a little more before you consider a swap
Old Mar 31, 2013 | 10:17 AM
nus_dogg's Avatar
Default Re: Engine.
It's not hard at all. It's pretty straight forward.
The hardest part I would say is the distributor wiring which I'm sure it's simple to do if you search. I've never done OBD2 H22 swap before, so I can't really say.
Old Mar 31, 2013 | 08:04 PM
Default Re: Engine.
Well I'm not swapping because I want to. My engine is about to be shot. So, I kind of have to.
Old Mar 31, 2013 | 08:19 PM
Default Re: Engine.
Rebuild your stock engine! Unless its easier to do the swap, I would try to keep an OBD specific motor in your Accord. Not to mention a manual conversion, which will probably cost you about another 150$. But so worth it.
Old Apr 1, 2013 | 07:41 AM
Default Re: Engine.
The mechanic drilled a hole into my engine. Irreversible.
Old Apr 1, 2013 | 07:42 AM
Default Re: Engine.
And what do you mean by manual conversion?
Originally Posted by NZXTInerTia
Rebuild your stock engine! Unless its easier to do the swap, I would try to keep an OBD specific motor in your Accord. Not to mention a manual conversions, which will probably cost you about another 150$. But so worth it.
Old Apr 1, 2013 | 10:21 AM
Default Re: Engine.
Ok, you REALLY need to your research. Converting your car from an automatic transmission to a manual transmission. Requires adding a clutch pedal, installing manual shifter (easy), and buying the parts that a manual Accord uses.
Old Apr 1, 2013 | 11:42 AM
daddy VTEC's Avatar
Default Re: Engine.
Just go with the h22 setup!!!!
Old Apr 1, 2013 | 01:06 PM
Default Re: Engine.
I kind of figured that's what you meant... But, not for $150.
Old Apr 1, 2013 | 01:07 PM
Default Re: Engine.
You're talking couple grand...
98cfprelude
Apr 9, 2012 01:12 AM
brandon_wright92
Feb 21, 2009 02:12 PM
socialistic
May 14, 2008 04:28 AM
951dc5
Mar 12, 2006 03:58 PM
spark90703
Jun 29, 2004 09:13 PM
