Ect coolant temperature sensor replacement
Old Jul 29, 2019 | 07:19 PM
Quimby55's Avatar
Default Ect coolant temperature sensor replacement
I'm probably making this more complicated than it seems cause it's dark and rainy, but how do you remove the under the distributor ECT 2 pin sensor for ecu not gauge 1 pin? My deep sockets (18/19mm) go right over the plug and hex, and don't seem to have any room to take it out with a 17mm? Or whatever size wrench. Being a bit lazy and not wanting to remove distributor or other sensors or hurt my precious dizzy o ring. Thanks
Old Jul 29, 2019 | 07:21 PM
Quimby55's Avatar
Default Re: Ect coolant temperature sensor replacement
Can I break off the ECT plug and socket it that way. New one is a 19mm easy install but original not so much... It's a 91 Accord DX btw
Old Jul 31, 2019 | 05:31 PM
Quimby55's Avatar
Solved and a thread with only an op. I ended up breaking off the plug from the sensor because I had a good one already that just takes a 19 or 3/4 socket over the sensor to thread in. I don't know if that's normal practice on these ECT sensors but only way I could get it out. I got some junkyard ECT sensors from Very nice much newer Acuras and very easy to get with a 19mm I believe and they're right on top. Car runs great now cel code 6 gone and a couple others I think 5 and 14 that came up when the sensor died.
Old Aug 2, 2019 | 10:49 PM
MAD_MIKE's Avatar
MM Gruppe B
FWIW.
Use a large 1/2" drive deep impact socket to install and remove these sensors.
Typical 3/8" and some 1/2" drive normal sockets are not quite deep enough for the sensors.
jemo1
Jun 5, 2013 05:55 PM
sammisty
Jan 29, 2013 06:13 AM
kwengca
May 10, 2010 10:27 PM
supermotothud
Dec 8, 2008 11:47 PM
foress_89
Jan 15, 2008 03:58 PM
