ebrake
Old Jan 11, 2007 | 07:51 AM
IsweatHONDA's Avatar
Default ebrake
i can lift my e brake about an inch before there is any tension. why does this happen and what can i do to fix it.
Old Jan 11, 2007 | 08:22 AM
Ross 2.0's Avatar
In a Junkyard near you.
that's normal. How many clicks can you get out before the brake will hold the car still in gear?
Old Jan 11, 2007 | 09:12 AM
Default Re: (Ross 4107)
im not sure but i do know that even with the ebrake all the way up i can still drive my car
Old Jan 11, 2007 | 09:14 AM
02 accord's Avatar
Default Re: (IsweatHONDA)
Tighten it up. If that doesn't work, check your rear brakes.
https://honda-tech.com/zerothread/1860107
Pictured is a 92, and it is the same setup in my 02. Should also be the same in yours.
Old Jan 11, 2007 | 09:20 AM
Default Re: (02 accord)
i had an oil change yesterday at the honda dealership and they said my rear brakes were fine...83% i think. ill have to try the tightening up thing.....thanks! any idea why this happens, is it just from normal wear and tear?
Old Jan 11, 2007 | 09:24 AM
lunarone's Avatar
LOL 83%... "Sir, your oil change was on good timing... you had 18.12% oil life left. Yeah, we also checked your brakes today. They are fine, you have exactly 83.1415% life left on them."
Old Jan 11, 2007 | 09:25 AM
Ross 2.0's Avatar
you determine the % left by measuring them.
You definitely have something wrong then. Try adjusting the cable and see what happens
Old Jan 11, 2007 | 09:34 AM
lunarone's Avatar
"83%" is only relative to what the original size of the pad/shoe was. Even if you DID know the original size of the pad, 83% is far too specific to say. That 17% you have already used might have taken a month to wear down, but the remaining 83% might only take a couple. You never know. Life is precious. The end.
and it sounds like you just need to tighten the e-brake cable.
LAKER HATER
Sep 12, 2005 09:01 AM
LiL accORd RideR
Oct 16, 2004 09:45 PM
grampafunk
Apr 21, 2003 11:51 PM
Sand
Dec 4, 2002 03:04 PM
