Driverside engine mount/bracket problem.
Old Nov 24, 2003 | 06:38 PM
-Bionic-'s Avatar
Former Sponsor
Default Driverside engine mount/bracket problem.
I'm driving a 1999 H22 accord. I'm using the stock engine mounts. However, the bracket on the driver side does not line up with the H22. I'm currently driving around with one screw. I know that areyouasian made a customized bracket, in which he shaped and drilled a solid piece of steel. I don't have the tools, and I don't know anyone who customizes this particular part. I remember reading that someone used a 97+ prelude bracket, but I can't find the post.
Could someone please help me out?
Thanks.
Old Nov 24, 2003 | 08:00 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: Driverside engine mount/bracket problem. (-Bionic-)
Could anyone with a 98+ accord tell me what engine mount/braket you use for your H22?
Old Nov 24, 2003 | 10:25 PM
philadd's Avatar
https://honda-tech.com/zerothread?id=473019
Further down from areyouasian's article, jeff652 stated another way in regards to that mount: " In regards to the top driver mount, there is an easier way. Re-use the Accord "arm" as above, but rather than making a bracket, simply drill a hole through the H22 engine mount bracket (the part that bolts to the block) and insert a long bolt (a suspension bolt is the perfect length) and put a nut on the bottom. Tha Accord 'arm' acts as a template for the drill bit so the hole is gauranateed to line up perfect. Once installed this way, it will hold without any problems."
the 97+ prelude bracket you were referring to was for the power steering pump.
I have not done the swap myself, but I hope this helps.
Old Nov 24, 2003 | 11:06 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: Driverside engine mount/bracket problem. (philadd)
Thanks bro.
See I'm using the F23 engine mounts, and jeff652 is talking about the H22 engine mount bracket. I heard about this, and I'm wondering which bracket he is refering to. Is it the 97+ engine mount bracket, or the 92-96?
Thanks
Old Nov 25, 2003 | 06:20 AM
-Bionic-'s Avatar
Former Sponsor
How many on this forum have a 6th gen H22 accord?
Old Aug 13, 2004 | 09:23 PM
PHiZ's Avatar
Default Re: (-Bionic-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">How many on this forum have a 6th gen H22 accord?</TD></TR></TABLE>
I "have" one. As in, I am responsible for it as a project, I am tackling the motor mount issue right now, and may have some fabbed up, it looks like there may be interest.
-PHiZ
Matiss Porietis
Jul 8, 2017 10:58 AM
asinclado
Nov 18, 2015 03:43 PM
Tachi
Aug 24, 2015 11:51 AM
EightV
Jun 29, 2009 03:13 PM
