digikey replacement map sensor
Old Jul 18, 2011 | 07:10 PM
LawlessOne's Avatar
Icon2 digikey replacement map sensor
I've been looking my butt off and can't find the topic or thread I had seen before.
It was concerning replacement part for MAP sensor from digikey.
Anyone seen it before? done it before?
my MAP sensor p/n: TN079800-2550 5V PS-20
digikey p/n: MPX4250AP-ND mfg p/n: MPX4250AP SENSOR ABS PRESS 36.3 PSI MAX
The two parts are very different in size and appearance. Original does not look as if it can be partially taken apart to remove/replace with digikey part, and the electrical connector on the sensor doesn't look that easy to remove either.
In addition, this digikey part has six pins, not sure if I do take the harness off that the three wires connect to a six pin connector.
Old Jul 18, 2011 | 07:37 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: digikey replacement map sensor
Why not just buy the correct item?
http://cgi.ebay.com/ebaymotors/90-93...7#ht_782wt_939
I think you're asking for issues by trying to install a completely different sensor on your vehicle and am not sure how you came to that conclusion.
Old Jul 18, 2011 | 07:49 PM
LawlessOne's Avatar
Well... like I said, there was a thread that I can not find anymore.
Otherwise, I wouldn't have known to get the part.
I understand what you mean. But the cost was insignificant by far, so if it doesn't work out it's not a big deal (which is the way it is looking at the moment)
Damn procrastination!
Old Jul 18, 2011 | 07:50 PM
LawlessOne's Avatar
I'm pretty sure it's the actual part, just not the actual housing.
Old Jul 27, 2011 | 08:25 PM
LawlessOne's Avatar
Ah Ha!... SUCCESS!!
It's in the Forced Induction section. Now to post or PM someone and find out the wire hook up!!
Saaaawwwweeeeet!
WalkerGSR1
Oct 27, 2006 02:01 AM
'90crxSI
May 23, 2006 06:53 AM
turbohondask
Apr 29, 2003 08:59 PM
