diffused corner light
I currently have clear cornering lights on my cd5 and am unimpressed by the light output (looks orangish and very broad projection) but i want the output like i did with the diffused stock ones so i was looking for diffused clear corners like on the jdm headlights, does anyone know where i can find some or clear corners with better output or is it just the bulbs?
You are getting a lot of light output from your corners because of the style of light you are using. It has tons of reflective material inside, and a very clear outer lens on top of that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">Describe more?
There is a OEM Stanley clear lense that you could buy, I see them in the FS/ebay every so often.</TD></TR></TABLE>
This sounds like your best option, as far as clear goes.
current clear light=crappy dim light output
wanted light=whiteish light output like the headlights, not orangish low like i have now,
idk the light is very broad and not directed, like a clear bulb in a lamp in your house, not like the soft white ones (orangeish as opposed to white) i was them to match my headlights as far as light color.
damn this is hard to explain
