A different overheating?!?!?!?!
Old Apr 23, 2007 | 04:14 AM
lax1089's Avatar
Default A different overheating?!?!?!?!
97 accord EX 108k miles
after i stop from driving like at a stoplight, the temperature guage slowly rises to about 3/4 of the way from the overheating mark. there are absolutely no leaks, the fans all run and work, the t-stat is new and properly installed, and its not a blown headgasket. any ideas?????????????
Old Apr 23, 2007 | 07:54 AM
gulfview's Avatar
Default Re: A different overheating?!?!?!?! (lax1089)
Bad sending unit? Defective water pump?
Old Apr 23, 2007 | 02:48 PM
lax1089's Avatar
Default Re: A different overheating?!?!?!?! (gulfview)
could be water pump....i havnt had that replaced (or tbelt)
Old Apr 23, 2007 | 03:00 PM
JDM_DC4_Fanatic's Avatar
it could be as simple as low on fluid. How do you know the t-stat is good? just because its new, doesnt always mean its good. New parts can be defective. The rad cap could be poor, and not holding the pressure in as it should. best thing to do is a coolant pressure test and see if it holds. then go from there.
Old Apr 23, 2007 | 05:26 PM
lax1089's Avatar
Default Re: A different overheating?!?!?!?! (JDM_DC4_Fanatic)
coolant pressure test checks out fine.
fluid as in coolant? i already mentioned above its good on coolant levels.
i dont KNOW the tstat is good but when i let the engine warm i feel the the upper and lower rad hoses and both are warm
Old Apr 24, 2007 | 12:01 PM
lax1089's Avatar
bump is anyone experienced enough to know this?
Old Apr 24, 2007 | 12:18 PM
notoriousB's Avatar
there may be an air bubble in the system - burp it using the bleed valve.
Old Apr 24, 2007 | 05:24 PM
lax1089's Avatar
Default Re: A different overheating?!?!?!?! (notoriousB)
how? (i kinda need things explained in detail or else i won't do anything because i really dont want to mess anything up)
Old Apr 24, 2007 | 06:09 PM
BLKFLSH's Avatar
Drain the coolant back out, open the bleeder valve, and refill. The heater should be turned to full heat. Read up on the system in the link below.
http://techauto.bravehost.com/...tance
Old Apr 24, 2007 | 06:43 PM
lax1089's Avatar
Default Re: A different overheating?!?!?!?! (BLKFLSH)
thanks
Mhillips
Jul 31, 2013 07:16 PM
SlowPokeEg
Jul 21, 2005 12:47 PM
petrv
Apr 18, 2004 09:27 PM
petrv
Apr 18, 2004 09:26 PM
