cv boot busted. Does Split CV boot work?
Old Mar 27, 2004 | 01:45 PM
david90's Avatar
Default cv boot busted. Does Split CV boot work?
I heard there are cv boot that is splited so you can install it without removing suspension components; are they reliable?
I just discovered the broken boot today. It doesn't make any wierd noises so joint is not damaged right and that i can just replace the boot?
Old Mar 27, 2004 | 04:13 PM
Chiovnidca's Avatar
Default Re: cv boot busted. Does Split CV boot work? (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">I heard there are cv boot that is splited so you can install it without removing suspension components; are they reliable?
I've never seen one that didn't leak.
Old Mar 27, 2004 | 04:42 PM
89_LXi's Avatar
Default Re: cv boot busted. Does Split CV boot work? (Chiovnidca)
They work as a temporary fix to keep most of the dirt and crap out, but they do leak and I wouldn't recommend them for any long term fix. I had two of them and they both fell apart after awile. One piece boot is definitely the way to go
Old Mar 27, 2004 | 06:04 PM
jwogen1's Avatar
you can get oem replacements for like $25. do it right and you wont have any problems
Old Mar 27, 2004 | 06:58 PM
david90's Avatar
oem sounds good. Is the cv bolt hard to remove? I had a run in with the crank bolt and had to bring it to the shop so they can break it for me. Anyway, I need a good tutorial with pic.
Old Mar 28, 2004 | 02:26 PM
scrap1ngsr's Avatar
Default Re: (david90)
I noticed that my inner boot was broken yesterday, what would happen if I didnt replace it? Also I replaced both of my outer boots and with the spilts ones and they seem to be fine
Old Mar 28, 2004 | 02:38 PM
2+2=5's Avatar
Default Re: (CivicSiR94)
what exactly do you mean by broke?
crack?
once the boot is leaky, the lube is gone, dirt and sand came into the axle, grinding everything up
Old Mar 28, 2004 | 02:42 PM
scrap1ngsr's Avatar
Default Re: (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">what exactly do you mean by broke?
crack?
once the boot is leaky, the lube is gone, dirt and sand came into the axle, grinding everything up</TD></TR></TABLE>
Yea it is cracked, its only the inner boot on the driver side. Should I replace the boot or think about replacing the axles?
B_Swapped93
Suspension & Brakes
13
Jul 30, 2013 06:19 AM
Joelrz
Dec 7, 2006 06:38 AM
redryder
Aug 28, 2005 07:33 PM
kb798
13
May 27, 2004 12:55 PM
