Air/Fuel Gauge
Old 02-28-2011, 12:07 PM
Hondero_PR's Avatar
Default Air/Fuel Gauge
I would like to know which wire do I have to splice from the 02 sensor. I would like to connect directly to 02 sensor rather than the ECU. The 02 sensor has 4 wires 2 blacks a green and white wire. Any help would be appreciated.
Old 02-28-2011, 12:28 PM
chikin pickle's Avatar
Default Re: Air/Fuel Gauge
There are four wires. Two blacks are the heater circuit. Signal wire is the one you want, I don't remember if it's white or green, but check for continuity to the chassis ground on each one to pick out the ground.
Old 02-28-2011, 12:33 PM
accord_raffi's Avatar
Are you trying to read from the stock narrowband? It's kind of pointless unless you have a wideband o2.
Old 03-10-2011, 03:49 PM
Hondero_PR's Avatar
Found it was the white wire. Thanks for everyone cooperation.
Old 03-10-2011, 05:24 PM
phootbag's Avatar
These things are a gimmick.
skata89
02-24-2007 07:41 PM
qazaq
04-28-2006 09:54 AM
ludelvr
07-16-2002 07:40 PM
2000_Si_On_Air
07-06-2002 06:35 PM
Quick Reply: Air/Fuel Gauge
