Couple Problems
Old May 17, 2006 | 10:01 AM
mayday3k's Avatar
Default Couple Problems
well first is... i got a 94 accord lx/ex, and for some reason, the exhaust rattles, like under the shifter, possibly further up toward the motor... the car has a new exhaust on it from the cat - back... also tightened down the heat shield, and even added a couple of screws to the heatshield... but the problem still happens... it only does the rattle thing, usually above 2000 RPMS... IDK
second problem... i got fuel leaking from the tank, and its got to be near the top of the tank, beacuse its leaking in a few different spots, which i know cant be the fuel line, because its coming from a couple spots... it seems when im low on gas, it doesnt leak, and when i just filled it up... it happens... also, when i park the car, itll leak to a certain point, and then stop, as if there is a hole in the top of the tank.... could this be???? THANKS IN ADVANCE...
Old May 17, 2006 | 10:49 AM
notoriousB's Avatar
Default Re: Couple Problems (mayday3k)
there is a hole in the top of the tank where the fuel pump goes in - maybe it's leaking from the seal there, or perhaps your fuel return line has a hole in it. you should be able to check that area from inside your trunk.
the rattle is probably the cat heat shield. just take it off and throw it away.
Old May 17, 2006 | 04:59 PM
hondadude's Avatar
that exhaust buzz has a service bulletin, they have tighter springs and different bolts for the intermediate pipe. You might be able to get some big washers under the springs and shut it up.
As far as the fuel leak; an old plumber told me that liquid runs downhill, so you can just follow the trail up to find the leak.
Old May 17, 2006 | 06:53 PM
mayday3k's Avatar
Default Re: Couple Problems (hondadude)
well as far as the fuel leak... i saw a tank on ebay for $69.99 + $30.00 shipping, but i noticed the gentleman selling it, lives like 10 minutes away... so im just gonna buy one, and replace the tank, and new fuel filter... and double check the lines... i noticed the tank has had a hole before, because i see a hole clogged up, now that i actually looked at it... and as far as the exhaust buzz, where am i putting in new springs or washers???? which part??? thanx in advance...
kevin
vulch
May 8, 2015 08:09 AM
digitalvice
Mar 26, 2013 02:42 PM
xitsmike
May 23, 2010 12:34 PM
redwards
10
Jun 20, 2007 06:02 AM
-Bionic-
Oct 26, 2005 09:16 PM
