Coolant temp switch/sensor
Old Feb 2, 2013 | 06:20 PM
zsiya's Avatar
Default Coolant temp switch/sensor
What would a bad coolant temp switch/sensor cause besides turning the cooling fan off and on? The switch on the front of the block was causing my fan to go crazy. I'm replacing this one but just curious what else these do for the engine.
Old Feb 3, 2013 | 08:00 AM
Bamber's Avatar
Default Re: Coolant temp switch/sensor
If I'm not mistaken, it won't do anything. The front one controls your fan, the single wire is your sender unit (to the gauges in the dash) and the wire closest to the firewall tells the ecu what's goin on. What's the issue?
Old Feb 3, 2013 | 10:05 AM
nus_dogg's Avatar
Wrong.
The front ECT on the upper radiator neck gives info to ECU to turn condensor fan on/off while the back ECT located on the thermostat housing control's the radiator fan.
Old Feb 3, 2013 | 01:29 PM
zsiya's Avatar
Are they both the same to replace (part #)?
Old Feb 3, 2013 | 03:10 PM
zsiya's Avatar
Found it. They're not.
SAMCRO08
Jun 6, 2013 05:39 PM
Thepowderblue
Jun 18, 2012 02:19 PM
97civicdx
Jul 20, 2010 05:04 AM
hotcivicsi
19
May 15, 2009 01:54 PM
zelifcam
Oct 21, 2002 12:29 PM
