Coolant problem
How do I know there's a leak in coolant? The splastic container is a normal level, there's no sign of leak/puddle. I refilled a bit yesterday on the radiator, but to today its all drained out or something. Should I replace my coolant hoses? hit me up
If you cant find a leak dont change the hoses. Does this car smoke a white smoke from the tail pipe? Does the engine start with a miss fire? A bad head gasket will cause acoolant consumption problem with no appearant leak noted. also check the oil level, if its higher than normal it could be coolant getting in the crankcase.
DC2point0
15
Mar 22, 2006 12:05 AM
