condensor fan problems
Old Sep 9, 2003 | 11:45 AM
HT Chaplain's Avatar
Loved
Default condensor fan problems
i have a 90 accord ex & the passenger side fan or condensor fan is not working, but when i wire the fan directly to the battery it works? what causes this and what to i have to do to fix it? Thanks
Old Sep 9, 2003 | 11:51 AM
pdr's Avatar
pdr
Is it plugged in?
Old Sep 9, 2003 | 06:04 PM
Stripped Honda's Avatar
99-0104
Default Re: (pdr)
it is probally the relay i would try to replace that and if you still have a problem then take it to some one who knows auto electric but i am pretty sure it is just a bad relay
Old Sep 9, 2003 | 08:11 PM
89_LXi's Avatar
Default Re: (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">it is probally the relay i would try to replace that and if you still have a problem then take it to some one who knows auto electric but i am pretty sure it is just a bad relay</TD></TR></TABLE>
That's what mine was, sort of. Noticed my a/c was kinda warm while idling and found my fan wasn't working (the large one though). Thought my fan motor was dead, but it came on when I jiggled the relay. Replaced the relay and it worked fine for awile and then started acting up again, and I found it to be the contacts between the relay and the power distribution box weren't making very good contact. I took a little screwdriver and carefully bent the little springy part of the contact in the fuse box (for lack of a better description, lol) so that they clamped together tightly, and I haven't had a single problem with it since (that was about 5 months ago, and I've used the a/c just about every single day since then, so they've been run quite a bit w/o prob)
Old Sep 10, 2003 | 05:00 AM
Loved
Default Re: condensor fan problems (legutki)
Thanks guys for your help.
19 crx 89
10
Aug 26, 2010 12:38 PM
Jonathan_ED3
Sep 27, 2008 10:11 AM
arluk3
Oct 14, 2007 12:05 AM
Corrado_club
Jan 10, 2007 05:29 AM
ToneDaBass
Nov 13, 2004 08:19 AM
