code 41..
Old Mar 6, 2002 | 11:32 PM
BigBlockCRX's Avatar
New User
Default code 41..
hey
I have a 90 accord ex 5spd and I put a 97 sohc vtec accord ex motor in it.. it runs pretty good,but it wont rev past 5k and its throwing a 41.. so whats a 41?
its the ONLY code I'm throwing
thanks
charles
Old Mar 6, 2002 | 11:35 PM
wizurd's Avatar
Default Re: code 41.. (BigBlockCRX)
I don't know the answer to your problem, sorry. I am just curious as to how you know the code it is giving you?
Old Mar 7, 2002 | 04:00 AM
CmptchAV6's Avatar
Default Re: code 41.. (wizurd)
if he has the little uplink for the ecu that is usually under the dash if you short 2 pins on it the check engine light flashes a certain way and allows you to see the code.
Old Mar 7, 2002 | 05:48 AM
4doorRS5spd's Avatar
New User
This might help......maybe.
http://www.hondasociety.com/board/sh...threadid=38537
[Modified by accord55, 2:48 PM 3/7/2002]
Old Mar 7, 2002 | 01:51 PM
AggAccord03's Avatar
Default Re: code 41.. (accord55)
Code 41 Oxygen sensor heater Check the heater for the proper voltage signal (see Section 4).
See - HondaSociety isn't a bad board sometimes...haha
Old Mar 7, 2002 | 06:16 PM
Accord1999's Avatar
New User
Default Re: code 41.. (AggAccord03)
Code 41: Primary Heated Oxygen Sensor. Heater system electrical problem/malfunction.
Old Mar 8, 2002 | 02:41 AM
niedejb's Avatar
Default Re: code 41.. (Accord1999)
I have all the F22B codes posted on my site under resources. ECU and ABS codes.....
sammybananas
Feb 19, 2013 10:45 AM
blwn95civic
Sep 19, 2007 11:30 AM
silentblackhat
Feb 18, 2005 10:39 AM
90da
Nov 6, 2003 10:15 AM
whagkangmakulet
Nov 25, 2002 12:27 PM
