Clock Light
Old Sep 16, 2005 | 08:05 AM
knucklhed's Avatar
Default Clock Light
I have a 2000 Accord and the light is either loose or burned out. Either way, how do you remove the clock from the dash to gain access to the bulb. Thanks
Old Sep 16, 2005 | 08:56 AM
Heat's Avatar
Default Re: Clock Light (knucklhed)
Here's the instructions for installing a trunk mounted CD changer, includes a lot of good information on taking apart the interior of the car including the clock.
http://www.handa-accessories.c...k.pdf
It's on page 6, Step #24. Basically it pops out, but be sure to have your screwdriver covered in masking tape or cloth to prevent scratching anything.
Old Sep 16, 2005 | 09:09 AM
AccordTunr's Avatar
Default Re: Clock Light (Heat)
Actually my clock light just blew. Where do you get the light bulb from?
Thanks...
Old Sep 16, 2005 | 09:12 AM
ricepicker's Avatar
Default Re: Clock Light (AccordTunr)
You have to buy a whole new clock since it is digital.
Old Sep 16, 2005 | 09:19 AM
knucklhed's Avatar
Heat,
Thanks for the quick response and the PDF file. I was trying to pry it from the sides of the clock.
Old Sep 16, 2005 | 09:44 AM
Heat's Avatar
Default Re: Clock Light (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">You have to buy a whole new clock since it is digital.</TD></TR></TABLE>
I had replaced my clock four or so years ago, had broken the clip on the back when I was removing it (didn't realize how the clip unplugged). It's only ~ $20 or so from the dealer.
I could swear that I've read posts about people replacing just the light in the clock, but maybe I'm mistaken.
Old Sep 16, 2005 | 10:47 AM
AccordTunr's Avatar
The clock still works, but if the light is intergrated with the LCD then I would have to buy a new unit.
Peace...
Old Sep 16, 2005 | 10:52 AM
2+2=5's Avatar
you are not correct, there's a bulb you can replace, maybe you should get to know your honda before passing infomation around huh?
Old Sep 16, 2005 | 10:57 AM
2+2=5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordTunr &raquo;</TD></TR><TR><TD CLASS="quote">The clock still works, but if the light is intergrated with the LCD then I would have to buy a new unit.
Peace...</TD></TR></TABLE>
It is NOT intergrated, there's a quick access slot for your bulb, all you need to do is pull the actual clock out, remove the harness and you'll see a circular slot marked by a Cross, stick in a phillip head screw driver to the cross and turn it loose, the bulb is inside.
Before another newbie starting to say it's integrated, i changed mine.
fergs96integra
Jun 5, 2013 03:32 AM
nhldogg
Feb 22, 2010 01:50 PM
lmrbtj
Feb 12, 2009 08:15 PM
Type_R_Kills
Aug 31, 2006 02:39 PM
B2FiNiTY
Jun 20, 2003 11:19 AM
