Checking ABS Codes
Old Nov 7, 2004 | 11:42 AM
SlammedCD7's Avatar
Default Checking ABS Codes
My abs light came on, is there a way to use a jumper or paperclip to check the abs codes like the CEL codes, i tried searching but the search is not working
Old Nov 7, 2004 | 02:10 PM
SlammedCD7's Avatar
Default Re: Checking ABS Codes (Wylie15)
bump
Old Nov 8, 2004 | 06:48 AM
JimBlake's Avatar
On my '95 Integra, it's exactly the same. If there's ABS errors, the ABS light will blink it's code instead of the CEL blinking.
What year? My ABS only flashes short. First & second digit of the code are determined by short or long spaces between the blinks. Check out the sticky thread at the top of the Integra forum, but I don't know what might be different for Accords...
Old Nov 8, 2004 | 11:11 PM
SlammedCD7's Avatar
Default Re: Checking ABS Codes (JimBlake)
i tried doing this, and it is what all of my searches came up with, but when i tried, the cel light just came on, it didnt flash it just was on untill i took the paper clip out, the cel was just on the whole time
Old Nov 9, 2004 | 03:56 AM
JimBlake's Avatar
If your engine ECU has no errors, the check-engine light will remain on the whole time while the jumper is connected. But it's the ABS light that should be blinking, if the ABS has any stored errors.
That's the way is is on my '95 Integra. Things are different year-to-year, probably different from Accord vs. Integra? I don't even know what year Accord you have...
joenoreason
Apr 28, 2007 08:56 PM
Wayne_Curr
Apr 13, 2006 03:07 PM
iLUVmyACCORD
Jan 14, 2005 06:13 AM
andrewasf77
Nov 26, 2002 09:19 AM
