Check engine light??
Old Jan 21, 2004 | 06:28 AM
prelude1897's Avatar
Default Check engine light??
My GF drive a 98 Accord, and her check engine light is on. How can I check to see what CEL it is throwing? Is there a site I can go to in order to see what each code means? I drive a Prelude and there is a site that tells me what each CEL is, so I was wondering if there is one for the Accord also.....
Thanks
Old Jan 21, 2004 | 06:33 AM
SiR EJ8's Avatar
as far as i know, the codes are the same for all hondas. wait a minute..........the codes are for hondas, but, some models have special codes. i.e. all wheel steering; codes for the v6 accords. and what not. you can look on google, search for honda ecu codes. that will give you the list. then look it up. as for getting the code. on mine, and many others, there is a lil plug that hangs down on the pass. side, to the left of the kick panel, might need a flashlight, and get in the floorboard to see it. take a paper clip, unfold it and put the two ends in each socket of the plug. turn key to RUN position, dont need to start. watch the CEL, it will blink. long=10, short=1. add the number up, look it up. hope that helps. SoLo.
Old Jan 21, 2004 | 06:42 AM
I8ayellowcrayon's Avatar
https://honda-tech.com/zerothread?id=468260
FAQ in the EF Forum. I'm not much on Accords, but most/all Civics have a little red light in the computer and you can just count those, but SoLo has an Accord, so I think you should listen to him over me.
Old Jan 21, 2004 | 10:38 AM
jweller's Avatar
Default Re: Check engine light?? (prelude1897)
how to get the codes
http://mywebpages.comcast.net/....html
all hondas use the same 2 digit codes, so any list should do. but here is the scanned pages from the Helms for the 98- 01 4cyl
http://www.honduh.com/showthre...d=107
Old Jan 21, 2004 | 11:04 AM
nuc79's Avatar
prelude1897,
yellow's method will work for obd-0 cars, and accords through 1990
solo's method will work for obd-1 cars. i.e., 94-95 teg, 92-95 civ, maybe 94-95 accord and lude,
but for your GF's '98(OBD-2), use jweller's method, or take the car by Autozone and have them scan it (for free of course) with their OBD2 scan tool.
Old Jan 21, 2004 | 11:20 AM
I think we have them all covered.
Old Jan 21, 2004 | 01:56 PM
briq4's Avatar
Default Re: (I8ayellowcrayon)
Most likely with a 98 it's going to be a clogged EGR valve. if your under 90K there's an extended warranty on it.
Old Jan 21, 2004 | 03:26 PM
SiR EJ8's Avatar
Default Re: Check engine light?? (nuc79)
just for future reference, 90-93 accords are also obd1. Thanks.
Old Jan 21, 2004 | 06:31 PM
ERICH's Avatar
call the place where you bought it from-if they have a mechanic, heck i've been one for 12 years, since i was 15, or call a dealership, you'd be surprised how nice they can be---sometimes
Old Jan 21, 2004 | 08:49 PM
jayisnameless's Avatar
Default Re: Check engine light?? (ERICH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERICH &raquo;</TD></TR><TR><TD CLASS="quote">call a dealership, you'd be surprised how nice they can be---sometimes </TD></TR></TABLE>
i work at a honda dealership haha and you are right they gotta be nice to get their paychecks
and you should go to a dealership, they have a pgm tester to let you know whats wrong and if u have warranty then your all set
Old Jan 21, 2004 | 08:59 PM
Crono139's Avatar
Default Re: Check engine light?? (jayisnameless)
Good job jweller. I knew you were going to post that info. I was about to do the same, then I saw your post.
Old Jan 22, 2004 | 05:47 AM
JDizzle96's Avatar
Id just take it to a shop and have them hook up the diagnostic system to it to see what code your accord is throwing. They most likely wont charge you for doing that. My check engine light is on just because the EGR valve needs to be replaced. It took them like a second to see what code it was throwing.
MuthaFodder
Mar 26, 2025 07:42 PM
barfo
Feb 21, 2015 06:11 AM
hodag17
Dec 13, 2005 07:38 AM
halfNhalf-83
Mar 15, 2004 10:00 AM
