Charging problem
Old Aug 6, 2008 | 12:33 PM
Mr Realistic's Avatar
New User
Default Charging problem
I have a 4-cyl, 1997 Accord LX Coupe that recently had the wiring re-done from the drivers side fuse box to the headlights. The battery won't charge. The alternator and battery are fine and I replaced the ECM today but that didn't work.
Everything works OK except the daytime running lights but they are on another circuit.
Trouble codes include IAT Sensor, EGR lift & O2 sensor, all of which are not on the charging circuit.
Any ideas?
Old Aug 7, 2008 | 08:03 AM
dramsey@vtaig.com's Avatar
Default Re: Charging problem (Mr Realistic)
sound like a wiring promblem, who did the wiring work for you. could be a complicated promblem, sorry i can't be more of a help.
Old Aug 7, 2008 | 08:16 AM
New User
Hi, I found the problem with the 1997 Accord charging problem. The bk/yellow wire from the alternator to the under dash fuseboard was bad.
Old Aug 7, 2008 | 08:18 AM
New User
Default Re: (Mr Realistic)
Hi, I found the problem. It was the black/yellow wire from the altenator to the under the dash fuse panel. The electric shop ran a new wire and it works fine. Thanks!
rutland
Aug 21, 2017 05:58 AM
CTR-GSR
Nov 17, 2006 11:15 AM
Officer
Oct 23, 2006 11:27 AM
kimo98GSR
Feb 3, 2005 09:10 AM
Jinxed
Dec 11, 2003 10:33 AM
